Problems with outgoing Calls on E1 Gateway
I am having a problem with making outside calls to the PSTN. I have a 2851 router with a VWIC-1MFT-E1 Card as a gateway. Below is my config:
version 12.4
ip cef
isdn switch-type primary-net5
voice-card 0
no dspfarm
controller E1 0/0/0
pri-group timeslots 1-31
description PRI Access Tel # 2609700
interface Loopback0
description Gestao
ip address 10.72.110.70 255.255.255.255
h323-gateway voip interface
h323-gateway voip id GK-PRA-PALJ ipaddr 10.0.110.2 1718 priority 100
h323-gateway voip h323-id PRA-PALJ
h323-gateway voip tech-prefix 7#
h323-gateway voip bind srcaddr 10.72.110.70
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
no cdp enable
no ip http server
no ip http secure-server
voice-port 0/0/0:15
cptone PT
mgcp bind media source-interface Loopback0
dial-peer voice 1 pots
description *** Primary Line for PSTN Calling ***
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
description *** Primary Target for Incoming PSTN Calls ***
destination-pattern .T
session target ipv4:10.72.154.2
dtmf-relay h245-alphanumeric
end
when I try to make an outside call I get the following output from a q931 debug:
ST_PR_PALJ_RA_W1#csim start 02607999
csim: called number = 02607999, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
ST_PR_PALJ_RA_W1#
Oct 2 13:14:28.488: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 2607999
Oct 2 13:14:28.488: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0086
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x80, '2607999'
Plan:Unknown, Type:Unknown
Oct 2 13:14:28.492: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0086
Cause i = 0x80AF - Resource unavailable, unspecified
Oct 2 13:14:28.524: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8086
Oct 2 13:14:28.524: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8014, call ref 0x86, event 0x2
Oct 2 13:14:28.524: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x0086
Cause i = 0x80E202 - Message not compatible with call state or not implemented
Call State i = 0x0B
Oct 2 13:14:28.564: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8086
Oct 2 13:14:28.564: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0086
Note that there is a TX -> DISCONNECT before the ANY response from the switch. What could be causing this?
I am not sure what is wrong here.
Thanks in advance,
Djassi
Silver
Re: Problems with outgoing Calls on E1 Gateway
You dialed 02607999, but the digits send to the PSTN are 2607999. Is the PSTN expecting the leading 0. If yes, then add the following command to dial-peer 1
prefix 0
Anup
hi anup, thanks for your reply, but the intended numbers are without the leading 0. The dial peer is configured to drop the leading zero so that the only number that goes through is 2607999.
Thanks again for your help
Djassi
Silver
It can be a problem with the channel selection order, as I can see at your debug there router can't complete the call because there is no resource available, it's trying to use the channel 31. You can configure the router to select the channel 0 first with the command "isdn bchan-number-order ascending" at the interface Serial0/0/0:15 level. Please, let me know if this works for you, if it doesn't works, would you mind to post the output of the "debug isdn q931"?
Hi icabrera, thanks for your post I added the command as you can see here but the problem remained:
Serial 0/0/0:15 config:
ST_PR_PALJ_RA_W1#sh run int serial0/0/0:15
Building configuration...
Current configuration : 156 bytes
no ip address
no cdp enable
end
q931 debug:
Oct 2 17:52:03.301: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 2607999
Oct 2 17:52:03.301: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x009F
Standard = CCITT
Channel ID i = 0xA98381
Exclusive, Channel 1
Oct 2 17:52:03.305: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x009F
Oct 2 17:52:03.333: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x809F
Oct 2 17:52:03.333: ISDN Se0/0/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x802D, call ref 0x9F, event 0xD
Oct 2 17:52:03.337: ISDN Se0/0/0:15 Q931: TX -> STATUS pd = 8 callref = 0x009F
Cause i = 0x80E20D - Message not compatible with call state or not implemented
Call State i = 0x0B
Oct 2 17:52:03.409: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x809F
Oct 2 17:52:03.409: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x009F
again note that my end sends a disconnect before any response from the isdn switch, doen't that seem strange to you?
Thanks again
Are you able to receive inbound calls just fine ? Did you try what Anup suggested ? Is the telco expecting a leading 0 ?
Hi Shanky :)
The telco is not expecting the leading 0, the dial peer is correct, but I also cannot receive incoming calls, I am actually troubleshooting it as I am responding to you... I am starting to think that there is a problem with the telco's switch. because on the inbound calls the destination number is missing the first number... In Cape Verde where we are... the numbering starts with 2 for the land lines, and 9 for the cell numbers. Then 21-87 for the municipalities and then the local numbers... so it's composed by 7 numbers. Here is what I am getting from a isdn q931 debug on an incoming call
Oct 2 18:08:23.823: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0014
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0083, '9926379'
Called Party Number i = 0x81, '609728'
Plan:ISDN, Type:Unknown
High Layer Compat i = 0x9181
Oct 2 18:08:23.835: ISDN Se0/0/0:15 SERROR: process_pri_simple: NO name in GTD
Oct 2 18:08:23.835: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8014
Oct 2 18:08:35.300: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0014
Cause i = 0x8090 - Normal call clearing
Oct 2 18:08:35.304: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8014
Oct 2 18:08:35.320: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0014
as you can see the called party number is only 6 digits. it should be 2609728.
Thanks again guys,
Djassi
Hi Djassi,
could you send this commands:
sh e1 controll
sh isdn stat
sh isdn servi
just to see if the E1 is clear.
Greetings
Rodrigo
Silver
Hi Djassi, I agree with you, I think it's a problem with the telco switch. With outbounds call the router is releasing the call because it's expecting some capabilities exchange with the switch that it doesn't happen and with inbound calls the problem is different. Try to check with your provider the setup.
982
