Proper command to use for modifying E/M card
Gurus,
I'm attempting to configure MOH on my CME, from a live source as documented here: http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_administration_guide_chapter09186a00801f12fa.html.
I've got the CD player ready, have had the adapter cable built to connect it to the E/M card, but I'm not sure how to modify the E/M card with the voice-port command. The card is on a 2851 router, and it is installed in the location marked "HWLC1". I am totally unfamiliar with this aspect, an am not sure what I should use (eg., voice-port 1/1/0, etc).
Any help woudl be greatly appreciated.
Re: Proper command to use for modifying E/M card
Once your router detects the VIC, it should appear in the config (sh run) as voice-port a/x/y. a, x and y can vary based on slot, port etc.
to configure e/m to support MOh, you will need to do the following,
voice-port 1/1/0 <-- e/m port 0 on slot 1.
auto-cut-through
signal immediate
operation 4-wire
input gain
dial-peer voice 1 pots
destination-pattern
port 1/1/0 <-- this needs to be e/m port
ephone-dn 1
number 3333
moh out-call
Hi, I have the following listed in my show run:
voice-port 0/0/0:23
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
So just so I understand, 'slot 1' (the middle number of the three) would refer to the actual location on the router marked HWLC1? So likewise, slot 2 or 3 would refer to the locations HWLC-2 and -3?
I see that you have many voice ports and you are trying to identify which port is e/m. You can do a show voice-port a/x/y to find out which port is e/m.
You can also do a sh voice-port summary to find out the interface types on each vic.
From your port numbering, you seem to have ,
a. 1 port t1 vwic on slot 0,
b. 2 port vic on slot 1,
c. 4 port vic on slot 2 and
d. 4 port vic on slot 3.
Most likely your slot 1 (2 port vic) should be e/m.
Do a show voice-port 0/1/0 or (0/1/1) to find out what kind of interface it is.
Sankar.
PS: please remember to rate posts!
The router is in a different location, but I wrote down what I have:
HWLC0: VWIC2-1MFT (T1 interface card)
HWLC1: VIC2 e/m card
HWLC2 & 3:VIC2-4FXO cards (not in use)
Thanks for the advice!!
131
