PSTN calls
Aman Soi
Hi All,
We are facing a problem while making PSTN calls to outside world using Cisco 2800 router configured as H.323 Gateway & integrated to Call Manager version 4.x.
On the router we have , VWIC-2MFT-E1 card on which PRI is terminated.
Setup was working fine but now when we call up, we need to dial two or 3 times before call gets matured.
router detail : c2800nm-spservicesk9-mz.123-11.T10.bin
can somebody guide on the same...
regds,
aman
Check status of your e1 line.
Show controller e1 x/x brief and show isdn service.
you can run debug isdn q931 and check what's going on as well.
nesharm2
Aman,
Apart from good suggestions from konrad
good things to check
1.what changed if it was working before ?
2.Did you have "direct indward dial" command under pots dial peer ?
Can you post the results of
sh isdn status
sh voice dsp
sh voice call summary
Do you know how many B and D channels you have on your PRI, could be possible that your using all the channels available on the PRI.
Justin
