PSTN Simulator Issues
Hi.
I'm implementing a 2801 as pstn simulator, i have another two 1760 acting as branch rtr with an fxs phone each one.
When a make a call between the 1760 the remote fxs phone doesn't ring and in the calling phone i only hear a dial tone but after 15 - 17 seconds i recieve fast busy tone.
Can anyone help me to see if a missed or fail with something in the conf.
Thnks
pstn-simulator#sh run
Building configuration...
Current configuration : 1996 bytes
version 12.4
hostname pstn-simulator
boot-start-marker
boot-end-marker
card type t1 0 2
network-clock-participate wic 2
dot11 syslog
ip source-route
isdn switch-type primary-ni
voice-card 0
controller T1 0/2/0
 cablelength long 0db
 pri-group timeslots 1-10,24
 description TRONCAL - AUTOMOTRIZ MONTERREY
controller T1 0/2/1
 description TRONCAL - AUTOMOTRIZ NOGALES
interface Serial0/2/0:23
 no ip address
 encapsulation hdlc
 isdn protocol-emulate network
 isdn incoming-voice voice
 no cdp enable
interface Serial0/2/1:23
 no ip address
 encapsulation hdlc
 no cdp enable
voice-port 0/2/0:23
voice-port 0/2/1:23
ccm-manager fax protocol cisco
dial-peer voice 10 pots
 destination-pattern 018115501...
 port 0/2/0:23
 prefix 8115501
dial-peer voice 11 pots
 destination-pattern 016188172...
 port 0/2/1:23
 prefix 6188172
pstn-simulator#
BR1#sh run
Current configuration : 1418 bytes
version 12.4
hostname BR1
tdm clock T1 1/0 both export line
voice-card 1
voice-card 3
controller T1 1/0
 framing esf
 linecode b8zs
interface Serial1/0:23
 no ip address
 encapsulation hdlc
 no logging event link-status
 no cdp enable
voice-port 3/0
 cptone MX
 station-id number 8115501000
voice-port 3/1
voice-port 1/0:23
dial-peer voice 1 pots
 incoming called-number 8115501...
 direct-inward-dial
 port 1/0:23
dial-peer voice 1000 pots
 destination-pattern 8115501000
 port 3/0
dial-peer voice 901 pots
 destination-pattern 01..........
 port 1/0:23
 prefix 01
BR1#
Current configuration : 1417 bytes
version 12.4
hostname BR2
card type t1 1
memory-size iomem 5
voice-card 1
voice-card 3
controller T1 1/0
 framing esf
 linecode b8zs
 no ip address
 encapsulation hdlc
 no cdp enable
voice-port 3/0
 cptone MX
 station-id number 2800
voice-port 3/1
voice-port 1/0:23
 port 1/0:23
 forward-digits all
 incoming called-number 6188172...
 direct-inward-dial
 port 1/0:23
 destination-pattern 6188172800
 port 3/0
BR2#
When  i try a call in the pstn i see this logs, and ipm not sure if this right see the same channel:
pstn-simulator#
*Apr  6 21:24:03.911: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8115501000, Called Number=016188172800, Voice-Interface=0x66C83310,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=11
   Calling Number=8115501000, Called Number=016188172800, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
*Apr  6 21:24:03.915: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr  6 21:24:03.923: %ISDN-6-CONNECT: Interface Serial0/2/1:9 is now connected to 8115501000 N/A
*Apr  6 21:24:03.927: %ISDN-6-CONNECT: Interface Serial0/2/1:9 is now connected to 8115501000 N/A
*Apr  6 21:24:21.679: %ISDN-6-DISCONNECT: Interface Serial0/2/1:9  disconnected from 8115501000 , call lasted 17 seconds
pstn-simulator#
Thnks
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi. This is the log output
Hi. This is the log output:
The call uses dp 11 as incoming dp but are "looped" to dp 11.
Try to invert "port" in dp 10 and 11.
Regards.
Regards.
That was the problem, only
That was the problem, only invert the port and work fine !
Thnks.
383
