05-15-2006 09:33 AM - edited 03-13-2019 01:16 PM
Folks,
I have a cluser that is composed of 1 pub and 3 subs. I have installed DBLHelper utility and it is showing me that the pub is red in color(out of sync), i tried republishing a couple of times but i get the same thing, anything else i can do to fix the problem?
05-15-2006 09:53 AM
DBL Monitor, MSSQLServer and SQLserver agent services running under SQLSVC?
No NIC missmatch?
Using Adminutility passwords are synch ?
All servers running same version?
CCMAdmin | Help | Component Versions | Out of synch
LMhosts and Hosts files are ok in ALL servers?
Servers meet Network and BW requirements?
05-15-2006 01:14 PM
Yes
Yes
No NIC missmatch?
Yes
Yes
Yes
Yes
Yes
But still the Pub shows up as red when i run dblhelper?
05-15-2006 01:20 PM
If all is good,
Try to recreate the subscription manually.
Otherwise open a TAC Case-
05-15-2006 01:29 PM
How do I do that?
I have one open already.
I will surely rate this post.
Thanks for the help.
05-15-2006 11:26 PM
Parwal you must try Manual Subscription below is link just follow n i think it should work for u
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
05-16-2006 06:03 AM
Are you sure yo are not hitting Bug CSCsa98895??
Symptom:
DBLHelper may incorrectly report that SQL replication is broken. DBLHelper will show a red frowny face
on the publisher giving an indication that SQL replication is broken.
Condition:
This problem may occur with DBLHelper 4.1(0.20) and earlier when the only SQLAgent job which is failing
is the Expired Subscription Clean Up job.
Workaround:
From MSSQL Enterprise Manager connect to the publisher SQL server and make sure that the Expired
Subscription Clean Up job runs successful.
