Community Member
Publisher is not replication
Folks,
I have a cluser that is composed of 1 pub and 3 subs. I have installed DBLHelper utility and it is showing me that the pub is red in color(out of sync), i tried republishing a couple of times but i get the same thing, anything else i can do to fix the problem?
Green
Re: Publisher is not replication
DBL Monitor, MSSQLServer and SQLserver agent services running under SQLSVC?
No NIC missmatch?
Using Adminutility passwords are synch ?
All servers running same version?
CCMAdmin | Help | Component Versions | Out of synch
LMhosts and Hosts files are ok in ALL servers?
Servers meet Network and BW requirements?
Community Member
Yes
Yes
No NIC missmatch?
Yes
Yes
Yes
Yes
Yes
But still the Pub shows up as red when i run dblhelper?
Green
If all is good,
Try to recreate the subscription manually.
Otherwise open a TAC Case-
Community Member
How do I do that?
I have one open already.
I will surely rate this post.
Thanks for the help.
Community Member
Parwal you must try Manual Subscription below is link just follow n i think it should work for u
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Silver
Are you sure yo are not hitting Bug CSCsa98895??
Symptom:
DBLHelper may incorrectly report that SQL replication is broken. DBLHelper will show a red frowny face
on the publisher giving an indication that SQL replication is broken.
Condition:
This problem may occur with DBLHelper 4.1(0.20) and earlier when the only SQLAgent job which is failing
is the Expired Subscription Clean Up job.
Workaround:
From MSSQL Enterprise Manager connect to the publisher SQL server and make sure that the Expired
Subscription Clean Up job runs successful.
126
