rif
Push Info 2 A Phone
Does any body know if Cisco has any plans in the future to be able to push information to there 7910, 40, 60?
Re: Push Info 2 A Phone
This can already be done with 7940 and 7960 using firmware loads from CallManager 3.1
See the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/3_1/ipphsrvs.htm
Note that if you want to see a banner or whatever on the phone without the user pressing the Services button, you can either use the Idle URL value or the and XML tags, which are mentioned in the above document.
The documentation on that URL you gave is rather short-spoken in the mentioned topic.
Please give me any more detailed information about it in order to understand its usage.
For example, example code, detailed description, and so on.
89
