Community Member
Q.SIG between PBX and 3.3
Can anyone clarify a few things for me. I have read a few earlier replies and found one CCO link, but ....
Can this only be achieved with MGCP not H.323?
Do 2600, 3600 and 3700s support this scenario (not just VG200)?
I assume no other additional applications or devices are needed over and above the Gateway, 3.3 and PBX etc?
Know of any good CCO configuration examples?
thanks, Mark.
1 REPLY
Anonymous
N/A
Re: Q.SIG between PBX and 3.3
I guess it makes sense only to have support for MGCP. If it is a H323 gateway like 2600/3600 then, the QSig support should be checked against the IOS that you are running on this router. It does not matter how QSIG is supported in CM in this case.
Talking about support of QSIG in CM, this URL explains it all
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/prod_release_note09186a008011e2c8.html#1344646
84
