Q931 alerting or progress on auto answered calls?
We have issues with a no-audio path on some calls when the phone is forwarded to voicemail (CfWAll).
The PSTN guy (DMS-100) says that he needs to see alerting or progress, but we are no sending it as it answers immediately.
We have a MGCP gateway, but a TpCall voicemail which connects on H225 intercluster trunk...
This is the Q931, but is the same for calls with or without audio.
(calls from within the DMS-100 have audio, external don't)
Nov 12 12:54:16: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0215
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839E
Preferred, Channel 30
Facility i = 0x91A12102018D02010F30190201010A0101A111A00FA10D0A010212083433383237333137
Protocol Profile = Remote Operations Protocol
0xA12102018D02010F30190201010A0101A111A00FA10D0A010212083433383237333137
Component = Invoke component
Invoke Id = 65421
Operation = Diversion Leg2
Calling Party Number i = 0x2180, '<removed>'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '<removed>'
Plan:ISDN, Type:Subscriber(local)
Sending Complete
Nov 12 12:54:16: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8215
Channel ID i = 0xA9839E
Exclusive, Channel 30
Nov 12 12:54:16: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8215
Nov 12 12:54:21: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0215
Cause i = 0x8090 - Normal call clearing
Nov 12 12:54:21: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8215
Nov 12 12:54:21: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0215
Anyone any ideas if the guy from PSTN is right?
thnx
1 REPLY
Bronze
Re: Q931 alerting or progress on auto answered calls?
sascha,
could you have a problem with DSPs ?
I had same problems (without tpcall) with some dsps
on the Gateway. After connect message we had dead air..
the only way to check this, is making a call on all b-channels and writing down the channel number to find the associated dsp..
good luck..
mehmet
141
