10-30-2007 06:00 AM - edited 03-13-2019 04:37 PM
Dear Voice Experts
Try to configure a CCME 4.2 on a router 2821 with latest QCT version 3.0.1 cause it would reduce a lot of work for command configuring.
But always get problems that none of the included phones in QCT are compatible to CCME 4.2
Any suggestions - cause i thought workaround will be to downgrade IOS for QCT of 4.0
But that's not really an longterm solution.
Do you plan to publish a new QCT Version ???
Many thanks and greets from Vienna
Helmut Schranz
11-05-2007 09:54 AM
Upgrading to lastest version of CME 4.2. or later will help run the archive command for GUI files.
11-05-2007 10:02 AM
Hi hadbou
I mean the combatibility of the piece of software "Quick Config Tool" for CCME what helps you to configure CCME easier.
You find the tool with the link : http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd802e9be9.html
Changeing the CCME version when i have to configure a piece could not be the solution ?
Thanks and greets
Helmut
11-05-2007 02:33 PM
Hi Helmut,
you will find that the thing that cisco does better, for sure is NOT gui / PC-based tools / etc.
These appears to be provided more to pass a "check-mark" on some tender requirements sheet, more than to be of real use.
So don't hold your breath for new improved versions, prepare solid config template and perhaps some custom text-based tool to help your repetitive configurations.
