QoS and voice signaling on TCCS interconnection
I try to connect 2 PBX using Transparent Clear Channel Signaling. It works!! Now I want to implement Qos for it.
We use a frame-relay link. I want to know which way is the best to use: LLQ or frame relay ip rtp priority?
How can we match the voice-signaling in order to make a voice-signaling class?
Is it enough if we put the ip precedence 5 on the dial peer interface in order to tag the voice packets? (voice + signaling)
Thank you
Re: QoS and voice signaling on TCCS interconnection
QoS depends on your network setup and also on your IOS. LLQ works far better than IP RTP PRIORITY and gives you much more flexibility. IP precedence 5 on all voip peers should be added but is not sufficient to guarantee voice delivery prior to data so LLQ or some other method is a must along with FRTS (Frame Relay Traffic Shaping). Below is a URL with sample configs on LLQ and FR:
You can modify the class-maps to define any class of traffic to be prioritized and be sure not to allocate more than 75% of the link bandwidth at all times.
http://www.cisco.com/warp/customer/788/voice-qos/voip-ov-fr-qos.html
Look under LLQ (above)
You can add this CLI for voice signaling, define a new access-list 102 so you have:
access-list 102 permit udp any any range 16384 37276
access-list 102 permit tcp any any eq 1720
since signaling for H323 is on TCP port 1720 this should cover it. Rest of configs is the same as URL.
Hope this helps.
Actually, here is the configuration
______ _____ _____ _____
| PBX |---E1-----| 7200 |-----Frame Relay 2 Mbps-----| 7200 |--E1-----| PBX |
The voice packets come from the PBX , not from a LAN.
Why the "ip precedence 5" won't be sufficient?
What is the bandwidth necessary for the voice signaling? I calculate that I need:
30 x 12kbps (for voice channels with CRTP) + 80kbps (for voice sig)
Am I completely wrong?
Do you think a configuration like that will be good?
class-map voice
match access-group 101
access-list 101 permit udp any any range 16384 32767
access-list 101 permit tcp any any eq 1720
access-list 101 permit ip any any precedence 5
policy-map mypolicy
class voice
priority 440
class class-default
fair-queue
interface Serial1/0.1 point-to-point
ip address....
frame-relay ip rtp header-compression
frame-relay interface-dlci 100
class voipFR
map-class frame-relay voipFR
no frame-relay adaptive-shaping
frame-relay cir 1920000
frame-relay mincir 192000
frame-relay bc 1920
service-policy output mypolicy
dial-peer voice 2 voip
destination-pattern 6000
session target ipv4:192.168.10.1
ip precedence 5
Thank you for you help
280
