QoS for Voice on an ADSL connection (Dialer interface)
1st of all sorry for crosspost, this is going to be more familliar with Voice people I think.
I have a lot of satelite sites with a simple ADSL cisco set-up (either 877/837 or in this case 1721) The config is identical, what is happening is that queueing never happens on the dialer interface under congestion so the voice traffic never gets prioritised and the call gets "choppy".
I am sure I am not the only person who needs QoS working on a dialer interface!
I have attached the relevant bits of the config (minus the VPN stuff) and here is the output of the policy map:-
peter#sh policy-map interface d1
Dialer1
Service-policy output: VOICE-POLICY
Class-map: voice-traffic (match-all)
463726 packets, 98224103 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: access-group name voice_traffic
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 50 (%)
Bandwidth 128 (kbps) Burst 3200 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 416124
Class-map: voice-signaling (match-all)
42905 packets, 3491605 bytes
Match: access-group name voice_control
Queueing
Output Queue: Conversation 73
Bandwidth 8 (kbps) Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: citrix (match-all)
571327 packets, 47176156 bytes
Match: access-group name citrix_traffic
Queueing
Output Queue: Conversation 74
Bandwidth 24 (kbps) Max Threshold 64 (packets)
Class-map: telnet (match-all)
218 packets, 27700 bytes
Match: access-group name telnet_traffic
Class-map: class-default (match-any)
7232707 packets, 4460899597 bytes
30 second offered rate 5000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 64
(total queued/total drops/no-buffer drops) 0/0/0
As can be seen, it never queues ANY traffic. An adentical config using an ethernet interface works no problem (in that case the Internet connection is presented as Ethernet, but it is not normal to do so now in the UK with ADSL)
Does anyone have a working config?
Peter
1 ACCEPTED SOLUTION
Re: QoS for Voice on an ADSL connection (Dialer interface)
Here is my working 877 QoS configuration.
class-map match-any Call-Signaling
match ip dscp cs3
match ip dscp af31
class-map match-any Routing
match ip dscp cs6
class-map match-any Voice
match ip dscp ef
policy-map V3PN_Teleworker_Out
class Voice
priority 90
class Routing
bandwidth percent 5
class Call-Signaling
bandwidth percent 5
class class-default
fair-queue
random-detect
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 0/35
vbr-nrt 384 384
tx-ring-limit 3
service-policy output V3PN_Teleworker_Out
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
ip access-group Outside_Inbound in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nbar protocol-discovery
ip nat outside
ip inspect IOS_FW out
ip ips sdm_ips_rule in
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username password
dialer-list 1 protocol ip permit
Rate this if it helps.
Matt
Bronze
match ip dscp cs3
match ip dscp af31
match ip dscp cs6
match ip dscp ef
class Voice
priority 90
class Routing
bandwidth percent 5
bandwidth percent 5
class class-default
fair-queue
random-detect
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/35
vbr-nrt 384 384
tx-ring-limit 3
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
ppp chap hostname
ppp chap password
Matt
Thanks for that, I didn't even thnk of using a subinterface! (tried unsucessfully on ATM) Doh!
You are a star.
peter.
Arrgghh, just tried your config and when entering the service-policy on the subinterface I get much the same error as before :-
peter(config-subif)#service-policy output VOICE-POLICY
CBWFQ : Not supported on subinterfaces
but I just noticed that I have to enter the vbr-nrt command first, however I notice the maximum values appear to change depending on IOS/Router.
Can you explain what this relates to in regard ADSL connection, and ideally what difference it will make in connection? I tried command lookup but it wasn't too helpful.
What software revision are you running on your routers? I know that there were alot of features, specifically in the 877 line that were only available in the advanced IP services version of the code.
For the 877 I know that both 12.4(4)T2 and 12.4(6)T support the above commands without a problems. As far as the 837, I know that 12.3(11)T10 supports the commands. These are the versions we are running. I am unsure about the 1700 series.
In regards to the vbr-nbt command, from what I understand you are supposed to set this to whatever your upstream bps is. In regards to what it actually does, I honestly cant remember what the instructer stated when he talked about this at networkers in 2004. Maybe someone else can elaborate. I am going to try and dig out my notes to give you a better explanation.
-Matt
Thanks Matt,
from your reply I investigated further and found this :-
http://www.cisco.com/warp/public/121/atm_vbrshape.shtml
which explains the whole thing.
For some reason the vbr-nrt command needs entered before the service policy command or it does not accept it, which is where I was going wrong.
I found that it works on the ATM0 interface without subinterface for adsl, but the VBR peak value on a WIC1-ADSL can only be set to what the line syncs at (upload), so it is difficult to pre-write a config to give the best attainable value until it's installed..
I have yet to try my QoS config under congestion, but I am considering using the rate-limit command to limit all inbound traffic to =(maxdownloadspeed minus Max upload speed) in order to maximise available bandwidth, but I have no idea if this will work!
Again, thanks for your help here, this has been bugging me for some months now.
Cheers,
Peter.
835
