Community Member
Qos for Voice over Frame Relay
I have implemented Qos on three of the 3810 router that it supply voice traffic
to remoter site. Each remote sight router is connected to a Mitel pbx. If I do a show
access-list it does not show any matches. Any suggesting will be helpful. Here is how 3810 are configured. Thanks
class-map voip
match access-group 100
policy-map llq-policy
class voip
bandwidth 128
class class-default
fair-queue
interface Serial0:0
description WAN Frame Relay Circuit #2
no ip address
encapsulation frame-relay IETF
service-policy output llq-policy
cdp enable
frame-relay traffic-shaping
frame-relay lmi-type ansi
map-class frame-relay 256k
no frame-relay adaptive-shaping
frame-relay cir 256000
frame-relay bc 32000
frame-relay mincir 128000
map-class frame-relay VOFR
frame-relay voice bandwidth 256000
frame-relay fragment 320
frame-relay bc 2560
frame-relay be 0
frame-relay fair-queue
access-list 100 permit udp any any range 16384 32000
Blue
Re: Qos for Voice over Frame Relay
Change your class-map voip so you match on IP precedence, (or DSCP depending on IOS) and you will have better luck. The precedence or DSCP bits should already be set by your dial peers. Your config will be simplier, and even better, it will work.
Dave
Community Member
I posted the full config for both central and remoter router. I had thought about using
DSCP Is there any problem using both in the access-list group.
Community Member
I have looked high and low. The IOS version on the routers are 12.1.13 I see no reference to match ip precedence under a class-map.
Just to mention, i think the ip address is missing under the interface, unless you have omitted from the config..
Here is the link which will explain QoS for VoIP over frame-relay.
http://www.cisco.com/warp/public/788/voice-qos/voip-ov-fr-qos.html
Above link also explain how to verify that and troubleshooting.
Community Member
There were subinterfaces that I omitted. Below is the config of the Central Router and remote site
cENTRAL Router
Version 12 .1
clock timezone EDT -4
network-clock base-rate 64k
network-clock-select 1 T1 0
ip subnet-zero
no ip domain-lookup
controller T1 0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 1
clock source loop-timed
linecode b8zs
mode cas
voice-group 1 timeslots 1-24 type e&m-wink-start
interface Ethernet0
description LAN link for Ops Center
ip address 192.168.x.x 255.255.255.0
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Serial0:0
no ip address
cdp enable
interface Serial0:0.1 point-to-point
description WAN Link Pasco Branch
ip address 192.168.X.X 255.255.255.252
frame-relay interface-dlci 16
class 256k
interface Serial0:0.2 point-to-point
description WAN Link Town & Country Branch
frame-relay interface-dlci 17
class 256k
interface Serial0:0.3 point-to-point
description WAN Link Largo Branch
frame-relay interface-dlci 18
class 256k
interface Serial0:0.4 point-to-point
description WAN Link Clearwater Branch
frame-relay interface-dlci 19
class 256k
interface Serial0:0.5 point-to-point
description WAN Link Temple Terrace Branch
frame-relay interface-dlci 20
class 256k
interface Serial0:0.6 point-to-point
description WAN Link Bradenton Branch
frame-relay interface-dlci 21
class VOFR
vofr cisco
interface Serial0:0.7 point-to-point
description WAN Link Spring Hill Branch
frame-relay interface-dlci 601
class VOFR
vofr cisco
interface BRI0
no ip address
shutdown
interface Switch0
no ip address
no fair-queue
router eigrp 2
network 192.168.x.x
network 192.168.x.x
no auto-summary
no eigrp log-neighbor-changes
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.x.x
ip route 192.168.X.X 255.255.255.0 192.168.X.X
frame-relay bc 2560
frame-relay be 0
voice-port 1/1
timeouts call-disconnect 0
voice-port 1/2
voice-port 1/3
voice-port 1/4
voice-port 1/5
voice-port 1/6
voice-port 1/7
voice-port 1/8
voice-port 1/9
voice-port 1/10
voice-port 1/11
voice-port 1/12
voice-port 1/13
voice-port 1/14
voice-port 1/15
voice-port 1/16
voice-port 1/17
voice-port 1/18
voice-port 1/19
voice-port 1/20
voice-port 1/21
voice-port 1/22
voice-port 1/23
voice-port 1/24
dial-peer voice 1 pots
forward-digits all
destination-pattern 42..
port 1/1
dial-peer voice 2 pots
forward-digits all
port 1/2
dial-peer voice 3 pots
forward-digits all
port 1/3
dial-peer voice 4 pots
forward-digits all
port 1/4
dial-peer voice 5 pots
forward-digits all
port 1/5
dial-peer voice 6 pots
forward-digits all
port 1/6
dial-peer voice 7 pots
forward-digits all
port 1/7
dial-peer voice 8 pots
forward-digits all
port 1/8
dial-peer voice 9 pots
forward-digits all
port 1/9
dial-peer voice 10 pots
forward-digits all
port 1/10
dial-peer voice 11 pots
forward-digits all
port 1/11
dial-peer voice 12 pots
forward-digits all
port 1/12
dial-peer voice 100 vofr
codec g729ar8
destination-pattern 40..
session target Serial0:0 601
dial-peer voice 25 pots
destination-pattern 9
port 1/1
dial-peer voice 26 pots
port 1/2
dial-peer voice 27 pots
port 1/3
dial-peer voice 28 pots
port 1/4
dial-peer voice 29 pots
port 1/5
dial-peer voice 30 pots
port 1/6
dial-peer voice 31 pots
port 1/7
dial-peer voice 32 pots
port 1/8
dial-peer voice 33 pots
port 1/9
dial-peer voice 34 pots
port 1/10
dial-peer voice 35 pots
port 1/11
dial-peer voice 36 pots
port 1/12
dial-peer voice 101 vofr
codec g729ar8
destination-pattern 41..
session target Serial0:0 21
remote
version 12.1
service password-encryption
hostname remote
logging buffered 64000 debugging
enable secret 5 1234
class-map voip
class voip
bandwidth 128
class class-default
fair-queue
ip subnet-zero
no ip domain-lookup
controller T1 0
framing esf
linecode b8zs
channel-group 0 timeslots 1-4 speed 64
description frame relay id# F4QRDA001114
controller T1 1
linecode b8zs
mode cas
voice-group 1 timeslots 1-3 type e&m-wink-star
bstun peer-name 192.0.X.X
bstun protocol-group 203 bsc-local-ack
bstun remote-peer-keepalive
interface Ethernet0
description LAN Interface
ip address 192.0.X.X 255.255.255.0
no ip route-cache
no ip mroute-cache
interface Serial0
bandwidth 9
no ip address
encapsulation bstun
no ip route-cache
no ip mroute-cache
delay 1
no keepalive
clockrate 9600
bstun group 203
bsc primary
bstun route address 4D tcp 192.168.X.X
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Serial0:0
no ip address
class 256k
class VOFR
vofr cisco
interface Switch0
no ip address
no fair-queue
router eigrp 2
network 192.0.X.X
network 192.168.X.X
network 192.168.X.X
no auto-summary
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.X.X
frame-relay bc 2560
frame-relay be 0
omitted
voice-port 1/1
echo-cancel coverage 32
voice-port 1/2
voice-port 1/3
forward-digits all
port 1/1
forward-digits all
port 1/2
forward-digits all
port 1/3
dial-peer voice 1 vofr
codec g729ar8
destination-pattern 2...
session target Serial0:0 17
dial-peer voice 2 vofr
codec g729ar8
dial-peer voice 3 vofr
codec g729ar8
dial-peer voice 4 vofr
codec g729ar8
end
Community Member
I have posted my config. The issue I have right now is echoes. Base on the my config how hard would it be to go Voip instead of using dlci or would it be better to use trunking. Any suggestion would be helpful
184
