QoS for voice when in bridging mode
I need to configure QoS for voice between 2 17xx routers in bridging mode. Since they are bridging because they are connecting the same subnet.
Telefonie is patched to 2950 switches on either side.
Switches have a link to either router on which ip routing is disabled for connectivity in bridging mode.
Is there a workaround without routing?
Silver
Re: QoS for voice when in bridging mode
Most of the Qos policies need routing to be enabled. For eg:- in the case of WFQ , You need IPprecedence or RSVP both of which will require you to route on the WAN link.
Paul
93
