04-13-2006 12:13 PM - edited 03-15-2019 04:18 AM
Hi, our environment consists of a 3 server call manager cluster in the headquarters and we have a branch office of about 30 IP phones that we have set up with centralized call processing off of the ccms at the headquarters with their own voice T1. So basically we are using the wan for call setup only. We have QOS on the router but we with are still having issues. The phones constantly reboot, slow functionality and and at times bad voice quality. I would like to know if anyone is using centralized call processing and if you have any suggestion that can help us. Also what is the bandwidth on the link? We have 512k and have since put an upgrade for a full t1 to see if it would solve our issue but not sure.
Laila
04-13-2006 11:07 PM
Centralized call processing works fine in many networks. The main idea for working IP Telephony is QOS enabled infrastructure (Everywhere in the network). You have to check your QOS configuration on all network devices. More detailed info you can find here.
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Don't forget to use Locations in CallManager configuration.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmsys/a02cac.htm
04-14-2006 09:07 AM
You should be fine if your QOS is properly configured. One potential gotcha is the tagging of voice signalling packets. Cisco has transitioned from using AF31 to using IP precedence 3. Make sure your voice control/signalling class map is set to recognize either, unless you are sure which is being used. A helpful hint for catching this kind of issue is to use random-detect dscp-based in your default class. Then you can see what tags are present in the default traffic.
Here is an example:
class-map match-any voicecontrol
match ip dscp af31
match ip precedence 3
match ip dscp ef
policy-map voiceT1
class voice
priority 600
class voicecontrol
bandwidth 64
class class-default
fair-queue
interface s0/0
service-policy out voiceT1
To verify:
show policy-map int s0/0
Please rate helpful posts.
05-07-2006 09:43 PM
Hi Laila, I am having the same issue at a site, did you resolve this?
Andy
05-10-2006 07:13 AM
question,
from reading the PDF's i saw that you need to enable the priority queue by issuing the command priority out...
05-10-2006 09:16 AM
That's correct on the switches. You have to make sure you've enabled QoS end-to-end and trust boundries are configured correctly. Make sure LLQ is matching correct DSCP values
class match-any RTP
match ip dscp ef
class match-any Control
match ip dscp af31
match ip dscp cs3
policy-map voip
class RTP
priority percent 33
class Control
bandwidth percent 2
class default-class
fair-queue
apply it to the engress WAN interface on the router. To check if packets are matched issue:
sh policy-map interface serial x/x
Also, look at shaping, compression and LFI
refer to www.cisco.com/go/srnd for QoS srnd doc,
HTH,
Chris
05-10-2006 06:08 PM
also,
from ealier discussions with QOS issues of my own, it was recommended that i not mix the priority and bandwidth commands for the qos policy. meaning if i use priority percent for my first class, utilize the same priority command for the second (with different weighting values of course)
05-11-2006 12:30 PM
I think they were talking about this:
The bandwidth and priority commands cannot be used in the same class, within the same policy map. These commands can be used together in the same policy map, however.
Within a policy map, you can give one or more classes priority status. When multiple classes within a single policy map are configured as priority classes, all traffic from these classes is queued to the same, single, priority queue.
So the limitation is if you are doing two priority classes, they should both be the same - either percent or bandwidth (and really, should be percent). We usually don't put the signalling in priority queue, just reserve bandwidth, as the post above did.
Mary Beth
05-17-2006 04:34 AM
Hi Laila,
- If you have QoS on the switches too, check if you set the trust on the switches correctly
- Use "DSCP" for trust at the switchports where CCM and WAN router are connected
- configure "ip accounting precedence in" and "ip accounting precedence out" on the interface and check if you see traffic in the correct classes ("show interface precedence")
- if you don't have voice bearer over the WAN you should not have a voice quality issue because of the WAN.-> check if clocking is okay ("show controller t1"). If you really have no voice bearer traffic, you don't need priority queueing.
- if you use DSCP for classifying, be aware that it can be AF31 (old) OR CS3. best would be to define both.
You have two problems which might not be interconnected:
- Voice quality
- Signalling problems (likely QoS problems)
Good luck,
Martin
