Qos issue
Hi guys, just a niggling issue i have. I have auto qos set across the Lan here, but when i do a show policy-map interface, when it lists the all the interfaces it doesnt show as any packets matching? does anyone know why this may occur?
As always any help always appreciated.
Dan
  • Other Collaboration Voice and Video Subjects
Re: Qos issue
This depends on the marking or classification within the service-policy, and whether you have applied it ingress or egress.
Can you please post the config to have a better understanding of exactly has been configured by Auto-Qos.
Rgds
Allan.
Re: Qos issue
ok
the thing is the qos should be cofigured end to end from the access-switch to the edge router
u need tomake sure that u have the right trust boundaries configured correctly
for example trust cos or cisco-phon on access ports and trust dscp on uplinks from switch to switch and from switch to router
this way u will keep ur marking along the way to the edge router
also have a look at the following link which is a case similer to urs i have discussed:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1b1f6/2#selected_message
good luck
if helpful Rate
103
