Bronze
QOS on incoming PSTN calls
hey,
havin a little issue with QOS fora while now. im just posting an output to see if anyone might have any suggestions...
one question though: im seeing that the QOS chosen is best-effort. is that the default output although we have configred fair-queue?, also, ive disabled VAD but still seeing it coming up as enabled
Telephony call-legs: 4
SIP call-legs: 0
H323 call-legs: 4
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 8
GENERIC:
SetupTime=755534860 ms
ConnectTime=755537260 ms
CallDuration=04:49:47 sec
InfoType=speech
TransmitPackets=852734
TransmitBytes=136437440
ReceivePackets=17876
ReceiveBytes=2827280
TELE:
ConnectionId=[0xA5A39D67 0x1BCD11CC 0x8963F7B4 0x6958
IncomingConnectionId=[0xA5A39D67 0x1BCD11CC 0x8963F7B
TxDuration=17387970 ms
VoiceTxDuration=354990 ms
FaxTxDuration=0 ms
CoderTypeRate=g711ulaw
NoiseLevel=-84
ACOMLevel=-3
OutSignalLevel=-82
InSignalLevel=-79
InfoActivity=2
ERLLevel=12
RemoteUDPPort=28132
RemoteSignallingIPAddress=
RemoteSignallingPort=1720
RemoteMediaIPAddress=
RemoteMediaPort=28132
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=h245-alphanumeric
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=TRUE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=ipv4:10.0.0.10
OnTimeRvPlayout=17056220
GapFillWithSilence=140 ms
GapFillWithPrediction=333870 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=65 ms
LoWaterPlayoutDelay=65 ms
TxPakNumber=17783
TxSignalPak=0
TxComfortNoisePak=160
TxDuration=17390420
TxVoiceDuration=354990
RxPakNumber=852851
RxSignalPak=0
RxDuration=0
TxVoiceDuration=17390400
VoiceRxDuration=17056220
RxOutOfSeq=15576
RxLatePak=0
RxEarlyPak=85
PlayDelayCurrent=65
PlayDelayMin=65
PlayDelayMax=65
PlayDelayClockOffset=1475850409
PlayDelayJitter=0
PlayErrPredictive=333870
PlayErrInterpolative=0
PlayErrSilence=140
PlayErrBufferOverFlow=760
PlayErrRetroactive=0
PlayErrTalkspurt=2
OutSignalLevel=-82
InSignalLevel=-79
LevelTxPowerMean=0
LevelRxPowerMean=-793
LevelBgNoise=0
ERLLevel=12
ACOMLevel=-3
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=65 ms
LostPackets=16712
EarlyPackets=85
LatePackets=0
VAD = enabled
1 REPLY
Re: QOS on incoming PSTN calls
The field "SelectedQoS=best-effort" is a reference for RSVP. This means it not selected in this dial-peer. This is not an issue if you aren't using RSVP. Set your QoS value in the dial-peer according to the protocol. H323 is at the dial-peer level.
To validate, use SPAN, RSPAN or VACL capture with Ethereal or something to check before your next hop. Or anywhere else on the network. Additionally on older IP phones you can sniff off of the pc port without any configuration with a host with a packet sniffer. 7970s (and probably the newer phones) enable span to pc port to sniff and you can see the traffic at your endpoint.
As far as VAD, you are probably using the default dial-peer. Set an explicit inbound dial-peer and disable VAD. Here is the document explaining dial-peers.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml#topic4
163
