QOS : Queuing to be done at the Edge or Distribution Layer?
Hi folks,
I have a setup which involves Avaya ip phones on Cisco infrastructure. The Cisco equipments are the catalyst 3550 (edge) and the 6500 (Distri & Core).
I'm pretty much a QOS newbie, and I've browsed through the LAN QOS and QOS best practices documentation, and I will like to know which part of the infrastructure should I apply Queuing to ? From the documentation, its either at the Edge/Distri or both. On either, is it better than the other?
appreciate any feedbacks. Thank you!
regards,
seanwy.
Super Bronze
Re: QOS : Queuing to be done at the Edge or Distribution Layer?
You would perform classification at the Edge, or perhaps use a trust-dscp model.
Queueing would be performed at any point where bandwidth may be contended - so this will probably include the edge, distribution, and core.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
Thank you for yr reply. It seems if I were to apply Queuing all all 3 layers, I believe the configuration will be pretty complex.
Just a side note, the Avaya IP phones are able to propagate both CoS & DSCP values. Thus, should I trust-dscp or trust-cos on the access (Edge) switch ?
much thanks!
regards,
Sean.
Blue
if your devices send DSCP & CoS, trust is OK.
be sure to verify your QoS at the access & distribution layers at least.
if your core is sufficient, you may have no real need to worry there.
Bronze
with my avaya ip phones i trust COS..
Example
interface FastEthernet0/5
Description to IP phone and PC
switchport mode access
switchport access vlan 10
switchport voice vlan 11
no ip address
spanning-tree portfast
mls qos trust cos
Also, for security reasons have the avaya ip phone re-write the "PC's dataport" (phones 2nd ethernet port connected to pc) to COS of 0
It's done by adding PHY2PRIO=0 in option 176 string or in 46xxsrttings script file via SET PHY2PRIO=0
274
