Quality Reporting Tool (QRT) Questions
Two questions about QRT:
1. Is there any documentation that gives a good guideline for analyzing the output of the QRT tool? I have gathered data, but don't know what is a good vs. a bad value under some of the columns, and multiple entries in a columnm, etc.
I have checked out the administrator's guide, serviceability admin and system guides and have found nothing more than the basics thus far.
2. When a user presses the QRT button during a call, are the statistics for just that point in time logged? If so how do I get more statistics for the rest of the call? Can they leave QRT window up without pressing the exit softkey, or do they need to keep pressing the QRT softkey multiple times? If so does the info get logged as one entry with multiple lines in the QRT display, or are they all logged seperately.
Bronze
Re: Quality Reporting Tool (QRT) Questions
Gold
1. Guidelines can be difficult to formulate. To kind of pull something out of the air, you should see less than 20ms average jitter if possible for high speed links, and loss should be as close to zero as possible although it does take 1% or so loss for problems to become audible.
2. Statistics for the entire call will be logged for that call leg, from any device that supports outputting CMR data. Unfortunately, a whole lot of gateways don't send CMR data. You should definitely get data from any skinny-based IP phone.
285
