Community Member
Question about extension mobility
I was wondering if there is a way to know the login / logout times of different users of extension mobility, maybe directly at the database or within some log at the CUCM. Does anyone know it? It's for a version 4.2, and for a version 6.1, so the procedure should be different.
Thanks in advance,
1 ACCEPTED SOLUTION
Re: Question about extension mobility
only using the EM traces
there is no reporting on that
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
there is an Extension Mobility API, you can use UserQuery or DeviceQuery but I am not sure what details are returned...
128
