04-16-2006 11:03 PM - edited 03-13-2019 12:55 PM
if VWIC-2MFT-E1 in 3845-V/k9 can do as voice gateway of ss7 .
i am not family of voice .
and i am eager for answer.
thank you for any help!
04-17-2006 11:33 AM
No, I believe only the as5xxx series in conjunction with the PGW2200 will allow you to interconnect TDM/SS7 in the Cisco product line. It's possible this has changed, but I don't think so.
Regardless, the VWIC-2MFT-E1 is only the multiflex trunk card and would need to be installed on NM-HDV or some equivelant to allow DSP usage. Put another way the E1 card would allow you to do 64K serial channels or E1 data links. In order to do voice you would need DSPs to do the g711alaw tone detection and g729 or other VoIP encoding. I hope this helps.
John Spade
webVoIP
04-17-2006 05:04 PM
thank you!
best regard!
04-17-2006 06:06 PM
could you tell me what different between ccs and ss7?
thank you very much!!!
