Question on 2821 and VWIC2-1MFT-T1/E1
Do I need an AIM card? I was told that I didn't with the 2821.
I'm trying to configure the PRI for incoming and outgoing calls. Do I have the right config?
controller T1 0/2/0
framing esf
clock source line independent
linecode b8zs
channel-group 0 timeslots 24
Re: Question on 2821 and VWIC2-1MFT-T1/E1
You should probably change your clock source to the provider or source
Depending on your Carrier, you may need to configure a D channel. Normally, it's 23 channels and 1 d channel... but it's up to the carrier and client.
But you can check this doc to see if this helps It's for a 3600, but still should work.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_configuration_example09186a0080094691.shtml
cheers
Hall of Fame Super Silver
For PRI you do not use channel-group use (assuming T1 not E1 in this example ):
pri-group timeslots 1-24 service mgcp
if used with CCM MGCP, if using CME or CCM H.323 use
Also, on the D-channel make usre you set the ISDN switch-type i.e. 5ESS, NI, DMS-100, etc, you'll need to know that from your provider:
interface Serial0/2/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager (if using MGCP)
no cdp enable
HTH, please rate all helpfull posts!
Chris
Do you need an AIM module to handle PRI calling?
You do not need an AIM card, but you do need DSPs resources for voice. The new 2800s support onboard DSPs.
The following will enable any installed DSPs for use.
voice-card 0
dspfarm
dsp services dspfarm
The configuration your showing is for a T1 not a T1 PRI. A T1/PRI uses pri-group instead of channel-group. The config is as follows
'select the correct switch type
isdn switch-type primary-4ess
controller T1 0/0/0
framing esf
linecode b8zs
interface Serial0/0/0:23
no ip address
no cdp enable
If you are using MGCP you will need to add service MGCP to the pri-group command and add the backhaul command to serial int.
455
