question on disaster recovery
if the unity server have problems....the guide suggest that we should backup all the thing on server...<br>that mean i should backup the commserver and return to normal after i restore this folder to a new setup nt server??<br><br>
1 REPLY
Anonymous
N/A
Re: question on disaster recovery
That means you should backup the entire hard drive, NOT just the commserver folder. This includes the registry, SQL databases and the Exchange mailstore/directory (AD). You'll need to use a backup package that has SQL and Exchange aware plug ins (i.e. Veritas).
typically you'd do a full backup of the entire HD and then do "delta" backups from that point forward. If you just backup the commserver directory and attempt to restore it somewhere Unity will never come back up on that box.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
87
