question on GMS codec
We would like to change the record format from G.711 to GMS6.10. Here are my couple questions:
1.Can I convert existing message codec?
2.Is the command setrecordformat only step I need besides restart unity?
3.What if I use IP phone or PBX phone to retrieve mail, will unity automatically play it with G.711 on the fly?
4.How can I verify GMS is running after I change the codec?
Thanks a lot
1 REPLY
Gold
Re: question on GMS codec
1. Unity can't do this.
2. Yes that is all you need to do.
3. Yes it will play g.711 or g.729a on the fly.
4. You could open the message with something like Cool Edit Pro but that really isn't necessary. If setrecordformat says GSM is in use, it is.
Keith
112
