Questions for upgrading cisco products for Win 7
We are using couple of Cisco applications at our environment.
Can you please let us know what are the latest versions  and the versions that are compatible with windoiws7
1. Cisco AnyConnect Network Access Manager( what versions are compatible with win7 )
2. Cisco AnyConnect Secure Mobility Client (what versions are compatible with win7 )
3.Cisco IP Communicator(what versions are compatible with win7 )
4.Cisco Systems VPN Client 5.0.03.0560(what versions are compatible with win7 )
Thanks for your help
ramya
1 REPLY
You can search cisco.com for
You can search cisco.com for the "name of the product + release notes" to get that information.
The only one that is relevant to this community, would be CIPC, all the other apps are VPN/security.
java
if this helps, please rate
www.cisco.com/go/pdi
34
