Questions on DSP which trapped in "busy" state.
I installed 3662 with 2 E1 connection to PSTN exchange.
Using R2 signalling with CO, and tested call connections between IP Phones and POTS phones.
During that tests, I found some DSP channels allocated to each E1 time slot were changed to state "busy" and never get back to "IDLE".
I made additional test and find that only when I dialed the destination phone number and hooked on before hearing "ring-tone", the DSP channel associated to that time slot the call seized got trapped in state "busy" and never backed to "IDLE" state.
In debugging log, the State Transition is stuck in "S_WAIT_STATS".
Following is the status display of my system.
Several channels are in "busy" state and call setup is not possible through this channels.
If any one faced this problem and solved this, advice me.
Is this a bug?
Thanks in advance...
SYSTEM : Cisco 3662
E1 CARD: NM-HDV-2E1-60 (VWIC-2MFT-E1-DI)
DSP Type : C549
DSP FW version : 4.1.28
VGW#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 000 01 None 4.1.28 busy idle 7 0 4/0:1 09 1 146/213
02 {medium} 4.1.28 IDLE idle 0 4/0:1 10 5 3931/2836
03 None 4.1.28 busy idle 0 4/0:1 11 18 828/931
04 {medium} 4.1.28 IDLE idle 0 4/0:1 12 7 1418/777
C549 001 01 None 4.1.28 busy idle 6 0 4/0:1 13 13 101/331
02 {medium} 4.1.28 IDLE idle 0 4/0:1 14 11 4066/4020
03 {medium} 4.1.28 IDLE idle 0 4/0:1 15 1 3469/1311
04 {medium} 4.1.28 IDLE idle 0 4/0:1 17 1 1766/1071
C549 002 01 None 4.1.28 busy idle 8 0 4/0:1 18 10 528/747
02 {medium} 4.1.28 IDLE idle 0 4/0:1 19 2 1590/979
03 {medium} 4.1.28 IDLE idle 0 4/0:1 20 7 1842/675
04 {medium} 4.1.28 IDLE idle 0 4/0:1 21 6 596/687
C549 003 01 {medium} 4.1.28 IDLE idle 7 0 4/0:1 22 8 2191/1293
02 None 4.1.28 busy idle 0 4/0:1 23 1 2397/907
03 {medium} 4.1.28 IDLE idle 0 4/0:1 24 10 1070/1190
04 {medium} 4.1.28 IDLE idle 0 4/0:1 25 3 4421/4624
C549 004 01 {medium} 4.1.28 IDLE idle 6 0 4/0:2 26 0 3597/2290
02 {medium} 4.1.28 IDLE idle 0 4/0:2 27 0 1753/1392
03 {medium} 4.1.28 IDLE idle 0 4/0:2 28 1 1694/1947
04 {medium} 4.1.28 IDLE idle 0 4/0:2 29 2 2258/2425
C549 005 01 {medium} 4.1.28 IDLE idle 6 0 4/0:2 30 5 50586/51476
02 None 4.1.28 busy idle 0 4/0:2 31 5 1845/1982
C549 013 01 {medium} 4.1.28 IDLE idle 6 0 4/0:1 01 0 1049/1216
02 {medium} 4.1.28 IDLE idle 0 4/0:1 02 0 490/641
03 {medium} 4.1.28 IDLE idle 0 4/0:1 03 0 195/330
04 None 4.1.28 busy idle 0 4/0:1 04 0 140/269
C549 014 01 None 4.1.28 busy idle 7 0 4/0:1 05 5 45/304
02 {medium} 4.1.28 IDLE idle 0 4/0:1 06 0 1167/754
03 {medium} 4.1.28 IDLE idle 0 4/0:1 07 3 558/765
04 {medium} 4.1.28 IDLE idle 0 4/0:1 08 1 151/232
VGW#sh voice call sum
PORT CODEC VAD VTSP STATE VPM STATE
4/0:1.1 - - - R2_Q421_IDLE
4/0:1.2 - - - R2_Q421_IDLE
4/0:1.3 - - - R2_Q421_IDLE
4/0:1.4 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.5 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.6 - - - R2_Q421_IDLE
4/0:1.7 - - - R2_Q421_IDLE
4/0:1.8 - - - R2_Q421_IDLE
4/0:1.9 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.10 - - - R2_Q421_IDLE
4/0:1.11 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.12 - - - R2_Q421_IDLE
4/0:1.13 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.14 - - - R2_Q421_IDLE
4/0:1.15 - - - R2_Q421_IDLE
4/0:1.17 - - - R2_Q421_IDLE
4/0:1.18 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.19 - - - R2_Q421_IDLE
4/0:1.20 - - - R2_Q421_IDLE
4/0:1.21 - - - R2_Q421_IDLE
4/0:1.22 - - - R2_Q421_IDLE
4/0:1.23 None y S_WAIT_STATS R2_Q421_IDLE
4/0:1.24 - - - R2_Q421_IDLE
4/0:1.25 - - - R2_Q421_IDLE
4/0:2.26 - - - R2_Q421_IDLE
4/0:2.27 - - - R2_Q421_IDLE
4/0:2.28 - - - R2_Q421_IDLE
4/0:2.29 - - - R2_Q421_IDLE
4/0:2.30 - - - R2_Q421_IDLE
4/0:2.31 None y S_WAIT_STATS R2_Q421_IDLE
VGW#sh voice trace 4/0:2
4/0:2 29 State Transitions: timestamp (state, event) -> (state, event) ...
1206423.588 (R2_Q421_IDLE, E_DSP_SIG_0000) ->
1206423.592 (R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK) ->
1206424.796 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_SETUP_ACK) ->
1206424.796 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_PROCEEDING) ->
1206424.800 (R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_0000) ->
1206428.212 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_VOICE_CUT_THROUGH) ->
1206428.212 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_CONNECT) ->
1206433.024 (R2_Q421_IC_ANSWER, E_HTSP_RELEASE_REQ) ->
1206433.224 (R2_Q421_IC_CLR_BWD, E_HTSP_EVENT_TIMER) ->
1206433.224 (R2_Q421_IC_CLR_BWD, E_DSP_SIG_0000) ->
1206435.224 (R2_Q421_IC_CLR_BWD, E_HTSP_EVENT_TIMER) ->
1206435.228 (R2_Q421_IC_CLR_BWD, E_DSP_SIG_0000) ->
1206436.516 (R2_Q421_IC_CLR_BWD, E_DSP_SIG_1000) ->
1206438.516 (R2_Q421_IC_CLR_FWD, E_HTSP_EVENT_TIMER) ->
1217302.920 (R2_Q421_IDLE, E_DSP_INTERFACE_INFO) ->
1217303.680 (R2_Q421_IDLE, E_DSP_SIG_1000) ->
1218997.132 (R2_Q421_IDLE, E_DSP_INTERFACE_INFO) ->
1218997.900 (R2_Q421_IDLE, E_DSP_SIG_1000) ->
4/0:2 31 State Transitions: timestamp (state, event) -> (state, event) ...
1216196.548 (S_SETUP_INDICATED, E_CC_PROCEEDING) ->
1216196.616 (S_PROCEEDING, E_VTSP_DSM_DIALING_COMPLETE) ->
1216197.340 (S_PROCEEDING, E_CC_ALERT) ->
1216197.340 (S_ALERTING, E_TSP_R2_DIAL) ->
1216197.568 (S_ALERTING, E_VTSP_DIAL_COMPLETE) ->
1216197.572 (S_WAIT_HOST_DISC, E_CC_DISCONNECT) ->
1216197.592 (S_WAIT_STATS, E_VTSP_DSM_DIALING_COMPLETE) ->
1216212.568 (S_WAIT_STATS, E_TIMER) ->
1217298.404 (S_WAIT_STATS, E_TSP_DISCONNECT_IND) ->
1218992.168 (S_WAIT_STATS, E_TSP_DISCONNECT_IND) ->
1216195.404 (R2_Q421_IDLE, E_DSP_SIG_0000) ->
1216195.408 (R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK) ->
1216196.548 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_SETUP_ACK) ->
1216196.548 (R2_Q421_IC_WAIT_ANSWER, E_HTSP_PROCEEDING) ->
1216196.552 (R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_0000) ->
1216197.568 (R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_1000) ->
1216199.568 (R2_Q421_IC_CLR_FWD, E_HTSP_EVENT_TIMER) ->
1217303.680 (R2_Q421_IDLE, E_DSP_INTERFACE_INFO) ->
1217304.436 (R2_Q421_IDLE, E_DSP_SIG_1000) ->
1218997.900 (R2_Q421_IDLE, E_DSP_INTERFACE_INFO) ->
1218998.488 (R2_Q421_IDLE, E_DSP_SIG_1000) ->
1 REPLY
Bronze
Re: Questions on DSP which trapped in "busy" state.
Assuming that your are running MGCP, this could be the bug CSCdu36732. I find this is fixed in 12.2(3.1)T.
581
