Queue Priority for VIPs
Hi.. I know a part of this question was already asked. However, I really need help with my current issue.
My client does not want to publish a separate RP number only for VIPs. What they want is for the VIPs to call into the main call center number, once they choose a Queue option they have the capability to send a DTMF tone of "VIP", or "847", so that they can be set a Priority of 10 within the Queue.
I want them to have the Priority capabilities no matter where they call from.
So with that, is this possible? And if so, what do I need to do so to present this "VIP" DTMF option, capture it, and then Prioritize the VIP caller?
Thanks in advance.
Lee
Blue
Re: Queue Priority for VIPs
Your script will look something like this
-start
-accept
-Get Digit String (this will play the opening greeting prompt and stuff the digits entered into a variable)
-if GetDigitString == "847"
- True
- Set Priority = "10"
- Go To CSQ
- False
- Go To CSQ
-CSQ
-Select Resource
etc,etc,etc
There are other ways to do this, switch string, etc but hopefully you get the jist.
Andy - berbee
Thanks Andy.. I'll check it out.
Lee
100
