"Disconnect Cause=16" debug decoder
Hi Team
phoneA39007-PBXA-(E1)-3845-(IP)-3845-(E1)-PBXB-PhoneB56076193
phoneA tried to ring phoneB but failed.Here is the partial output of debug voip ccapi inout:(part1)
cc_api_call_setup_ind_common:
Interface=0x70C8A654, Call Info(
Calling Number=39007(TON=Subscriber, NPI=Private, Screening=Not Screened, Presentation=Allowed),
Called Number=56076193(TON=Subscriber, NPI=Private),
Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE
cc_process_call_setup_ind:
>>>>CCAPI handed cid 2665026 with tag 0 to app "Default"
ccCallProceeding:
Progress Indication=NULL(0)
ccCallAlert:
Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
ccCallAlert:
Call Entry(Responsed=TRUE, AlertSent=TRUE)
cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
ccSaveDialpeerTag:
ccSaveDialpeerTag:
Outgoing Dial-peer=123
ccConferenceCreate:
(confID=0x71BFA85C, callID1=0x28AA42, callID2=0x28AA43, tag=0x0)
ccConferenceCreate:
Conference Id=0x71BFA85C, Call Id1=2665026, Call Id2=2665027, Tag=0x0
cc_api_get_xcode_stream:
cc_api_get_xcode_stream : 4163
cc_api_bridge_done:
Conference Id=0xEA87D, Source Interface=0x70C8A654, Source Call Id=2665026,
Destination Call Id=2665027, Disposition=0x0, Tag=0x0
ccConferenceCreate:
Call Entry(Conference Id=0xEA87D, Destination Call Id=2665027)
ccConferenceCreate:
Call Entry(Conference Id=0xEA87D, Destination Call Id=2665026)
cc_api_bridge_done:
Conference Id=0xEA87D, Source Interface=0x66ADA0F8, Source Call Id=2665027,
Destination Call Id=2665026, Disposition=0x0, Tag=0x0
cc_generic_bridge_done:
cc_api_caps_ind:
Destination Interface=0x70C8A654, Destination Call Id=2665026, Source Call Id=2665027,
Caps(Codec=0x6EFFF, Fax Rate=0xFF, Vad=0x3,
Modem=0x2, Codec Bytes=0, Signal Type=3)
cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=250(ms), Fax Nom=300(ms))
cc_api_get_delay_xport:
CallInfo(delay xport=FALSE)
cc_process_notify_bridge_done:
Conference Id=0xEA87D, Call Id1=2665026, Call Id2=2665027
could you please advise what caused the disconnection?
Much appreciated
Tony
Re: "Disconnect Cause=16" debug decoder
output part 2:
cc_api_caps_ind:
Destination Interface=0x66ADA0F8, Destination Call Id=2665027, Source Call Id=2665026,
Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
CCAPI/cc_api_caps_ind:
CCAPI/cc_api_caps_ack:
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=7348)
cc_api_caps_ind:
cc_api_caps_ack:
cc_api_caps_ack:
cc_api_voice_mode_event:
Call Id=2665027
Call Entry(Context=0x71EE3A24)
Call Id=2665027
cc_api_call_disconnected:
Cause Value=16, Interface=0x672470C0, Call Id=2665026
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
cc_api_get_transfer_info:
Transfer Number Is Null
ccConferenceDestroy:
Conference Id=0xEA87D, Tag=0x0
cc_api_bridge_drop_done:
ccCallSetAAA_Accounting:
Accounting=0, Call Id=2665027
cCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
cc_api_call_disconnect_done:
Disposition=0, Interface=0x66ADA0F8, Tag=0x0, Call Id=2665027,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
ccCallDisconnect:
Disposition=0, Interface=0x672470C0, Tag=0x0, Call Id=2665026,
Bronze
tony,
a decimal value of 16 is disconnect cause "normal call clearing".
can you post your config? your problem can be a codec issue, because you have a match of dial-peer tag "0".
greetings
mehmet
Hi Mehmet
The calling number is (563)39007 and should come from dial-peer 5632 as below:
dial-peer voice 5632 voip
destination-pattern 563[1-3]....
session target ipv4:10.192.63.11
dtmf-relay h245-signal
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs5 media
Don't know why it matches dial-peer 0 instead of dial-peer 5632.
A silly and simple question,should I config "incoming called-number ....."under dial-peer 5632?
how?
Hi Mehmet
Still want to consult you.Should the default dial-peer look like below?
dial-peer voice 1 voip
codec g711ulaw
or simply use the following command?
Thank you so much for your help.Appreciated.
Tony
17405
