"Media Inactive Detected" problem
I am having problem on on-net VoIP calls where the call setup is allright but no audio is passed. The output from "sh call act voi brief" is:
11F2 : 60 -1983049246ms.59 +13570 +29150 pid:2 Originate 1075577
dur 00:00:15 tx:1414/28280 rx:1415/28300 10 (normal call clearing (16))
IP 172.21.124.235:26294 SRTP: off rtt:239ms pl:27180/0ms lost:0/2/0 delay:60/60/70ms g729r8
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
11F2 : 59 -1983049246ms.60 +13570 +29150 pid:100 Answer 8983456
dur 00:00:15 tx:1415/28300 rx:1414/28280 10 (normal call clearing (16))
Telephony 1/0/1:23 (59) [1/0/1.23] tx:27260/27260/0ms g729r8 noise:-84dBm acom:45dBm
Has someone encounter this problem or would like to share the possible solution? thanks
Silver
Re: "Media Inactive Detected" problem
Make sure there are no IP routing issues in your network.
Anup
Silver
That media inactive detected stuff is n and n/a because you are not using it, it is a different feature that you can use for some things, if you activate it - i have never messed with it, but that stat is a red herring. My vote goes with a routing issue, that is the cause of one way voice 98% of the time, unless you have a dsp issue - which we have seen more of lately, but you should see errors in the log about that, and most often you will see that after things work for a while, and then stop. If you have an h323 gateway, make sure you are using h323-gateway voip bind srcaddr ip_address, and if it is mgcp gateway, if you have a loopback address built, the mgcp and rtp packets will source from that address, make sure it is routeable from your endpoint.
Mary Beth
The call can ring the other side but when we pick up the phone, nothing is heard. IP and Call routing are in place correctly. We are using CME 3.2 and have enable some features like: rtp send-recv, codec class with options of g729r8 and g711ulaw, and call fast start. ANy other possibilities? thanks
Silver
Well, just because the ring gets there does not mean that the rtp packets get from there back to you - so if you call the phone, the other party hears it ring and picks up and says hello, and you do not hear anything, then that could still be a routing problem. The other thing we have seen more often lately is problems caused by rtp header compression - like someone runs autoqos on a router on one side, not realizing it would enable that, and the other side does not have it enabled. Also we have had some brand new code that has trouble with rtp header compression, it will work fine for a while, and then you just randomly lose audio, we did not really need it so just disabled it and things were fine. But, if this is CME, what kinds of calls are you having this problem on, phones local to the CME calling where? One thing we ran into with CME specifically was that you need to make sure that every dial peer in the path has VAD disabled.
Mary Beth
thanks for your comments. I did some tests as follow:
- extended ping from CME H323 IP (loopback) and from local voice int to the gatekeeper without any issue. Would this confirm the correct routing?
- offnet calls (incoming and outgoing local, LD and IDD PSTN) - no problem. The IDD PSTN only being seized whenever communivation with gk failed (lowest preference).
- IDD on-net via telco which is routed to a global gateway for off-net -> no problem (audio can pass through).
- site-to-site on-net -> NO AUDIO at both sides.
Tried to isolate the problem with the above tests, but still no clue.
here is voice config (partial). The GK is a softswitch and it is not using "session target ras" command as Cisco GK does.
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
h323
h450 h450-3 timeout T1 1500
h245 tunnel disable
voice class codec 1
codec preference 1 g729r8 bytes 40
codec preference 2 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
telephony-service ccm-compatible
ccm-compatible
dial-peer voice 203 pots
corlist outgoing pstn
tone ringback alert-no-PI
destination-pattern 9T -> for local and LD calls
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/1/0:23
dial-peer voice 30 voip
translation-profile outgoing LD
preference 1
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:x.x.x.x (GK Proxy address)
dtmf-relay h245-signal
no vad
dial-peer voice 113 voip
translation-profile outgoing strip1or9
preference 1
destination-pattern 9001T (IDD onnet- primary path)
voice-class codec 1
voice-class h323 1
ip qos dscp cs5 media
no vad
dial-peer voice 213 pots
preference 5
destination-pattern 9001T (IDD offnet if via onnet failed)
direct-inward-dial
port 0/1/0:23
prefix 001
this issue is because of routing make sure routing is in place i m sure it will work.
Silver
I believe the gatekeeper will make the decision on the call routing, and then send the destiniation address for the actual rtp stream back over to the call originator, so the ip connectivity/routing has to be verified between the two endpoints. Are these two ip phones? If one device is registered to your CME, what is the other side, and where in relation to the originator?
Mary Beth
Silver
Also, the peers being matched in your first sample output were 2 and 100 - what do those looks like?
- IDD on-net via telco which is routed to a global gateway for off-net -> No Problem (audio can pass through).
1241
