"Simple" VoIP design 2811 4fxo CCM4.1
I have a 2811 with 4fxo, only 1 in use. I've installed and configured CCM4.1 I cannot seem to get the 2811 to register with the Call Manager. When I issue a show ccm I get the following response.
MGCP Domain Name: csg2811bgw2
Priority Status Host
Primary Down 192.168.128.52
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 14:02:22 PCTime Jan 11 2006 (elapsed time: 01:
Last MGCP traffic time: 15:31:39 PCTime Jan 11 2006 (elapsed time: 00:
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Backhaul/Redundant link is down
Configuration Error History:
FAX mode: cisco
I know it's pilot error but I've read everything I can find to figure out what I've done wrong. Any help would be great.
Daniel
Re: "Simple" VoIP design 2811 4fxo CCM4.1
I would suspect your configs. You have a domain name configured as well. So under CCM config pages for this MGCP gateway the name should match format. Post your configs so that we can troubleshoot better. Also see if you can get a screenshot of the CCM gateway configuration page.
Ok here is a screenshot and the 2811 config.
One thing straight off my head, I see your service command should call the application as "mgcpapp". You are missing the "p" in your configs.
Are you ale to ping from Callmanager to router and vice versa ?
See if the above fix helps!
PS: Please remember to rate helpful replies!
Ok I fix the missing 'p' and yes the router and the CCM server can ping each other. Still status shows down.
Daniel,
I would also do a "no mgcp" , wait a few seconds - when you will get a message saying MGCP APP teardown complete and then do a mgcp again. This basically disables and enables the MGCP process in the router.
See if that helps!
Also have you ensured that you have specified the right modules in the right slot in callmanager gateway configuration page ?
Ok did the "no mgcp" still no dice. Also, if you refer to the screen shot I sent earlier and here is the "show voice ports summary" you'll see that the ports are assigned correctly.
csg2811bgw2#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/2/0 -- fxs-ls up dorm on-hook idle y
0/2/1 -- fxs-ls up dorm on-hook idle y
0/2/2 -- fxs-ls up dorm on-hook idle y
0/2/3 -- fxs-ls up dorm on-hook idle y
0/3/0 -- fxo-ls up dorm idle on-hook y
0/3/1 -- fxo-ls up dorm idle on-hook y
0/3/2 -- fxo-ls up dorm idle on-hook y
0/3/3 -- fxo-ls up dorm idle on-hook y
I've verified everything I can have read and even wiped out the router and server to start over again. Obviously I'm doing something wrong. Can anybody point me in the right direction?
Daniel
Do you have an active phone line plugged into 0/3/0 (FXO) ? Since we made a few changes earlier, can you update a sh run, sh ccm-manager, ping output to callmanager, as well as screenshot of gateway config page as well endpoint ?
140
