ratio of DSP's to voice calls
Folks,
Could someone point out good documentation on the relationship between DSP's and the voice channels or calls.
Please correct me of i am wrong, you require 1 DSP for 1 voice channel or voice call.
Re: ratio of DSP's to voice calls
you are correct.
There are two kinds of Cisco DSP modules; the 542 and the 549. The 542 is the modules used in the devices that only support the FXO/FXS WICs. These support 1 FXx call per DSP and cannot, to the best of my knowledge, be used as a DSPFarm for conferencing or transcoding.
The 549 is the kind most often refered to when taking about DSPs. These are the DSPs used to support high-density voice in 2600/3600 and the 175X routers. These can be used to set up a DSPFarm for transcoding and conferencing, depending on router platform. The number of calls they support depends on the complexity of the codecs in use. One 549 DSP can support 4 Medium-complexity codec (i.e g.711) calls (apperently the PR people didn't like "low-complexity") and 2 high-complexity codec calls (i.e. g.729).
If you want to look it up yourself you can here:
http://www.cisco.com/en/US/partner/products/hw/gatecont/ps2250/products_tech_note09186a008011537d.shtml
and here:
http://www.cisco.com/en/US/partner/tech/tk652/tk701/technologies_tech_note09186a00800b6710.shtml
223
