Re: Difference between HWIC-1FE and HWIC-4ESW
m-laing
I am trying to find out the main difference between the HWIC-1FE and HWIC-4ESW cards.
Also I have a cisco 2811 router that is configured with one Fastethernet connected to DSL and the other port connects to mt LAN and METRO (using subinterfaces), is this the best practice?
ivillegas
Level 6
Level 6
HWIC-4ESW is the 4-port single-wide 10/100BaseT Ethernet switch HWIC. The 4ESW is a L2 switch and is cost effective.
HWIC-1FE is 1-port Fast Ethernet HWIC. The HWIC-1FE is a true L3 interface and is expensive. It has feature parity with an onboard FE interface except for OAM support, which is delayed.
HWIC-4ESW has the capability to setup VLAN but they are not the routed ports Whereas, HWIC-1FE has the same characteristics as Onboard FE ports.
