re-routing rejected calls on Call Manager
Scenario: CCM 3.2.3 contains a route pattern pointing to a route list. Route list has 2 Route Groups each with one gateway defined. Note both gateways are IOS talking H323 with the CCM.
Question: Under what circumstances does the the CCM attempt to re-route the call to the second route group?
I.e. What ISDN release cause in the DISCONNECT msg trigger the re-attempt? Also is this configurable if I want to re-attmpt when I receive a DISCONNECT with cause 0x29 (Temporary Failure)...
Thanks in advance.
1 REPLY
Re: re-routing rejected calls on Call Manager
120
