RE : Upgrade CallMgr 3.x to 4.1 Upgd, MCS-7835
Dear all my expert,
Refer to belows, Please advise the steps/idea to perform the works? Your effort shall be highly appreciated. Merry Christmas ! Kindest regards
Publisher
CM4.1-U-K9-7835=SW CallMgr 3.x to 4.1 Upgd, MCS-7835, 2500 Svr Usr Lic 1
300679-B21 1GB Memory Kit 1
First Subscriber
CM4.1-U-K9-7835= SW CallMgr 3.x to 4.1 Upgd, MCS-7835, 2500 Svr Usr Lic 1
Second Subscriber
1 REPLY
Blue
Re: RE : Upgrade CallMgr 3.x to 4.1 Upgd, MCS-7835
Are you on CM 3.2 or greater or 3.3 or greater? This makes a huge difference in the upgrade process.
Either way, I would first purchase spare drives for each 7835. Power down the servers, remove the hard drive from slot 1, label that hard drive, and put in the new hard drive. Let those drives mirror. This way you can roll back to your old conifuguration instantly if needed.
If you are on CM 3.2 or less:
1. Upgrade to CM 3.3
2. After that you can upgrade to 4.1 and follow the link below:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/upgrade/upg413/upgrfrom.htm
CM 3.3 or greater
Just follow the link above.
please rate posts.
andy - berbee
88
