Real-time call flow
Real-time call flow and menu system flow can be viewed using what utility or service in Unity ?<br><br>
Re: Real-time call flow
You can use the call viewer and the status monitor utilities to do this.
Anil Verma
Cisco Systems
anilve@cisco.com
Anonymous
N/A
The test is looking for "status monitor" here.
There's actually two status monitors... there's the web based status monitor that shows basic call activity on each port and there's a StatusMonitor.exe found under \commserver that shows much more details/conversation events and the like for calls on specific ports you select to monitor.
I always use the EXE version since it's much quicker and more detailed than the web based version... the UI is a little goofy, however.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
113
