Community Member
Rebooting GK monthly to avoid memory leak issue causing GK non functional
We are running gatekeeper IOS version 12.3(11r)T2 where we have to reboot GK monthly to avoid memory leak issue causing GK to be nonfunctional after some time.
It was recommended to have monthly reboots to avoid the memory leaks. It has worked since it has avoided any additional memory leak. The reboots were recommended by Cisco to avoid the memory leak.
Does any one know if there is fix for this now or if any new IOS version has a fix.
Any help will be appreciated.
Brajesh.
Hall of Fame Super Gold
Re: Rebooting GK monthly to avoid memory leak issue causing GK n
I think that this question should go to Cisco and one should not accept reload based workarounds.
Brajesh,
12.3(11r)T2 sounds like the IOS bootloader version. Can you copy the output of "show version." I can do a quick search to determine if there are any know leaks.  Do you know which process actually leaks? I agree that you may want to open a TAC SR to start profiling memory utilization to determine the cause of the leak.
To view the current memory allocation use,
show process memory sorted
-Felipe
Community Member
Felipe,
Here is show version.
vus-cvpgk1#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9_IVS-M), Version 12.4(15
)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 23:16 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
vus-cvpgk1 uptime is 2 weeks, 4 hours, 7 minutes
System returned to ROM by reload at 23:28:25 GMT Mon May 3 2010
System restarted at 23:30:02 GMT Mon May 3 2010
System image file is "flash:c3825-adventerprisek9_ivs-mz.124-15.T7.bin"
Cisco 3825 (revision 1.1) with 1011712K/36864K bytes of memory.
Processor board ID FTX1025A308
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
1930760K bytes of ATA System CompactFlash (Read/Write)
The below bug seems to be close to our scenario. Please have a look.
CSCsw23397
1st Found-In
12.4T
12.4(15)T7
12.4(15)T8
Voice Gateway may leak memory for DSMP EVENT chu and DSMP DSP REQ chunk
Symptoms: A Cisco Router acting as a voice Gateway may leak memory for DSMP DSP REQ chunk and DSMP DSP REQ chunk
Conditions: The symptom appears to be triggered by calls that disconnect prematurely.
Fixed-In
12.4(22)MD1
12.4(20)T2
12.4(23.12)M
12.4(22)T1
12.4(23.12)T
12.4(23.12)PI10
12.4(23.15.1)PIX11
12.4(22)MDA
12.4(23a)M
12.4(23.15.4)PIC1
12.4(24.5.1)PIX11
12.4(15)T9
12.4(24.5.2)PIC1
12.4(22)XR
12.4(22)YE2
I wouldn't expect that to be the bug unless the gatekeeper gateway also has TDM/analog interface handling calls. Do you have any information on the process that's leaking? Can you get the output of "show proc mem sorted" or provide the previous TAC SR number opened to originally address the issue?
Community Member
Earlier resolution what we found from Cisco is to reboot GK to fix this issue.
Please find the command output.
Processor Pool Total:  919148940 Used:   24673240 Free:  894475700
      I/O Pool Total:   37748224 Used:   12959664 Free:   24788560
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   64213880   24742544   31780752          0          0 *Init*
  68   0     659772       1328     640444          0          0 USB Startup
122   0 3760476856 3760018464     470240          0          0 gk process
118   0     365608       1052     367364          0          0 EAPoUDP Process
  26   0     264500          0     274000     113400          0 EEM ED Syslog
214   0     247992          0     255196          0          0 QOS_MODULE_MAIN
254   0     161220      10404     167812          0          0 EEM Server
   1   0     112392      13968     119596          0          0 Chunk Manager
   0   0   61174996   63634536     104152     258728          0 *Dead*
   4   0      65588          0      90792          0          0 EDDRI_MAIN
225   0      66852          0      80056          0          0 Crypto IKEv2
130   0      74304          0      74256          0          0 CEF process
248   0      75212       9024      73392          0          0 Syslog Traps
178   0      66416        252      73368          0          0 HTTP Process
229   0      45288       3204      67288          0          0 Crypto ACL
  63   0      57904        252      64856          0          0 VNM DSPRM MAIN
212   0        940          0      62144          0          0 http client proc
  95   0      49456          0      56660          0          0 ACCT Periodic Pr
101   0      49444          0      56648          0          0 IP ARP Retry Age
183   0      32136        252      39088          0          0 CCVPM_HDSPRM
143   0      39244        252      38060          0          0 DHCPD Receive
201   0      26200          0      36404          0          0 CCVPM_HTSP
134   0      10052          0      35256          0          0 COPS
102   0     234876     144492      34628          0          0 IP Input
271   0      17980          0      31252          0          0 IP SLAs Responde
  46   0      45512        800      30712          0          0 rf task
175   0      16812        252      29764          0          0 IPS Auto Update
270 578    4164412    4144008      27816          0          0 Virtual Exec
  18   0      22452       2400      27256          0          0 ARP Input
121   0       1068        252      26020          0          0 Border Element p
145   0      18944        252      25896          0          0 SCTP Main Proces
215   0        284          0      25488          0          0 RPMS_PROC_MAIN
267   0        252          0      25456          0          0 tHUB
  71   0          0          0      25204          0          0 RF_INTERDEV_SCTP
   9   0          0          0      25204          0          0 Crash writer
  78   0          0          0      25204          0          0 CF_INTERDEV_SCTP
216   0          0          0      25204          0          0 VoIP AAA
224   0       9816        252      22768          0          0 Crypto IKMP
180   0      12592        252      19544          0          0 CIFS Proxy Proce
  54   0      11688          0      18892          0          0 mxt5100
182   0      10556        504      17256          0          0 Crypto HW Proc
211   0      10052          0      17120          0          0 cpf_process_tpQ
217   0      31220      11892      16828          0          0 crypto engine pr
  97   0       9380        252      16332          0          0 CDP Protocol
263   0      10020        912      16312          0          0 EEM Policy Direc
207   0       8244          0      15448          0          0 Skinny HW confer
264   0      11856       9888      15172          0          0 Syslog
  39   0      24152        968      15024          0          0 Net Background
252   0      12388       4504      14848          0          0 VLAN Manager
218   0       2428        832      14800          0          0 Crypto CA
157   0       3972          0      14176          0          0 HTTP CORE
272   0    3212352    3211452      14172          0          0 IP SNMP
275   0       1152        252      14172          0          0 IP SNMPV6
277   0      25868       9248      13856       6804          0 SNMP Traps
  40   0       1400       1096      13508          0          0 IDB Work
227   0      13872      12640      13372          0          0 IPSEC key engine
273   0     582992          0      13272          0          0 PDU DISPATCHER
274   0   16630556   17213548      13272          0          0 SNMP ENGINE
276   0          0          0      13256          0          0 SNMP ConfCopyPro
  55   0          0          0      13204          0          0 sal_dpc_process
  35   0        252        252      13204          0          0 XML Proxy Client
116   0        252        252      13204          0          0 SSM connection m
  41   0        252        252      13204          0          0 Logger
221   0          0          0      13204          0          0 encrypt proc
  33   0        252        252      13204          0          0 Dialer event
223   0        252       1188      13204          0          0 Crypto IKE Dispa
  23   0          0          0      13204          0          0 Policy Manager
120   0        252        252      13204          0          0 KRB5 AAA
108   0        504        504      13204          0          0 PPP Hooks
167   0          0          0      13204          0          0 VPDN call manage
126   0        316        316      13204          0          0 PPP IPCP
142   0          0          0      13204          0          0 L2X Data Daemon
132   0          0    1060728      13204          0          0 TCP Timer
133   0    5281532       9604      13204          0          0 TCP Protocols
  99   0        252        252      13204          0          0 Ethernet LMI
  73   0          0          0      13204          0          0 AAL2CPS TIMER_CU
125   0        252        252      13204          0          0 PPP IP Route
111   0          0          0      13204          0          0 SSS Test Client
110   0          0          0      13204          0          0 SSS Manager
174   0          0          0      13204          0          0 IPS Process
   8   0          0          0      13204          0          0 OIR Handler
155   0        252        252      13204          0          0 ATM OAM Input
  86   0        252        252      13204          0          0 Ethernet Timer C
162   0        252        252      13204          0          0 X.25 Background
  85   0        252        252      13204          0          0 Ethernet CFM
156   0        252        252      13204          0          0 ATM OAM TIMER
  25   0       5336          0      12540          0          0 Entity MIB API
256   0       2664          0      12256          0          0 EEM ED Counter
  79   0       5304        252      12256          0          0 Dot1x Mgr Proces
   0   0      12052    7132656      12052          0          0 *Sched*
251   0       4660          0      11864          0          0 trunk conditioni
197   0       2260        568      10896          0          0 Crypto WUI
244   0        868          0      10460          0          0 EEM ED Resource
124   0        224          0      10428          0          0 IP RIB Update
   5   0       3352        252      10364          0          0 Check heaps
123   0         76          0      10280          0          0 IP Background
235   0          0          0      10204          0          0 Crypto Device Up
245   0        612          0      10204          0          0 EEM ED Track
150   0          0          0      10204          0          0 CES Client SVC R
257   0        612          0      10204          0          0 EEM ED Interface
  98   0        252        252      10204          0          0 Ethernet OAM Pro
  91   0        252        252      10204          0          0 Dot11 auth Dot1x
  90   0          0          0      10204          0          0 pmkid
  89   0        252        252      10204          0          0 Dot11 aaa proces
  43   0          0          0      10204          0          0 Per-Second Jobs
258   0        612          0      10204          0          0 EEM ED IOSWD
259   0        612          0      10204          0          0 EEM ED None
260   0        612          0      10204          0          0 EEM ED OIR
261   0       1224          0      10204          0          0 EEM ED SNMP
262   0       3060          0      10204          0          0 EEM ED Timer
153   0        252        252      10204          0          0 Adj Manager
255   0        612          0      10204          0          0 EEM ED CLI
119   0        252        252      10204          0          0 IP Host Track Pr
195   0    1422732     838072       9980          0          0 TPLUS
  82   0       2500        252       9452          0          0 DTP Protocol
219   0          0          0       9204          0          0 Crypto PKI-CRL
231   0          0          0       9204          0          0 Key Proc
220   0          0          0       9204          0          0 Crypto SSL
   3   0       2100          0       9168          0          0 gk dns process
100   0       1072          0       8276          0          0 IP ARP Adjacency
181   0       1192        252       8144          0          0 URL filter proc
  16   0        744          0       7948          0          0 IPC Seat Manager
138   0        732        160       7936          0          0 L2MM
278   0       1044        504       7744          0          0 NTP
203   0        436          0       7640          0          0 CCVPM_R2
210   0        336          0       7540          0          0 CCSWVOICE
280   0      10256       1484       7492          0          0 AAA Accounting
268   0        224          0       7476          0          0 CEF Scanner
114   0        504        252       7456          0          0 Spanning Tree
135   0        504        252       7456          0          0 Dot1x Supplicant
137   0        504        252       7456          0          0 Dot1x Supplicant
136   0        504        252       7456          0          0 Dot1x Supplicant
242   0        224          0       7428          0          0 DATA Collector
241   0        224          0       7428          0          0 DATA Transfer Pr
176   0        388        252       7340          0          0 SDEE Management
  36   0        252          0       7320          0          0 IGMP Input
213   0        228          0       7296          0          0 DHCPD Database
144   0        252        252       7276          0          0 PPPoE Flow Contr
204   0          0          0       7276          0          0 EPHONE MWI Refre
128   0          0          0       7220          0          0 SNMP Timers
105   0        252        252       7204          0          0 TurboACL chunk
106   0          0          0       7204          0          0 IPv6 RIB Redistr
103   0          0          0       7204          0          0 ICMP event handl
139   0          0          0       7204          0          0 MRD
140   0          0          0       7204          0          0 IGMPSN
141   0        252        252       7204          0          0 RLM groups Proce
  96   0        252        252       7204          0          0 AAA Dictionary R
  94   0          0          0       7204          0          0 AAA ACCT Proc
  93   0        252        252       7204          0          0 AAA Server
146   0          0          0       7204          0          0 IUA Main Process
147   0        252        252       7204          0          0 RUDPV1 Main Proc
148   0          0          0       7204          0          0 bsm_timers
149   0          0          0       7204          0          0 bsm_xmt_proc
  92   0          0          0       7204          0          0 Dot11 Mac Auth
151   0        252        252       7204          0          0 Dialer Forwarder
152   0          0          0       7204          0          0 IP Cache Ager
  88   0        252        252       7204          0          0 Dot11 Mgmt & Ass
154   0        252        252       7204          0          0 Flow Exporter Ti
  87   0          0          0       7204          0          0 linktest
  84   0        252        252       7204          0          0 EtherChnl
  83   0        252        252       7204          0          0 PI MATM Aging Pr
158   0          0          0       7204          0          0 RARP Input
159   0          0          0       7204          0          0 Transport Port A
160   0          0          0       7204          0          0 IPv6 Inspect Tim
161   0          0          0       7204          0          0 PAD InCall
131   0          0          0       7204          0          0 Socket Timers
163   0        252        252       7204          0          0 PPP Bind
164   0        252        252       7204          0          0 PPP SSS
166   0        252        252       7204          0          0 RBSCP Background
107   0        252        252       7204          0          0 MOP Protocols
129   0          0          0       7204          0          0 Asy FS Helper
104   0        252        252       7204          0          0 TurboACL
127   0          0          0       7204          0          0 IP Traceroute
171   0          0          0       7204          0          0 Auth-proxy AAA B
172   0          0          0       7204          0          0 CHKPT EXAMPLE
173   0          0          0       7204          0          0 CHKPT DevTest
  77   0          0          0       7204          0          0 CES Line Conditi
  76   0        252        252       7204          0          0 Call Management
112   0          0          0       7204          0          0 SSS Feature Mana
177   0          0          0       7204          0          0 Select Timers
  75   0          0          0       7204          0          0 IGMP Snooping Re
179   0        252        252       7204          0          0 CIFS API Process
  74   0          0          0       7204          0          0 IGMP Snooping Pr
  72   0        252        252       7204          0          0 Ether-Switch RBC
  70   0          0          0       7204          0          0 RF_INTERDEV_DELA
  69   0        252        252       7204          0          0 VMI Background
184   0       7632        252       7204          0          0 FLEX DSPRM MAIN
185   0          0          0       7204          0          0 FLEX DSP KEEPALI
186   0        252        252       7204          0          0 CRM_CALL_UPDATE_
187   0        252        252       7204          0          0 HDA DSPRM MAIN
113   0          0          0       7204          0          0 SSS Feature Time
189   0        252        252       7204          0          0 AAA Cached Serve
190   0        252        252       7204          0          0 ENABLE AAA
191   0          0          0       7204          0          0 EM Background Pr
192   0          0          0       7204          0          0 Key chain liveke
193   0        252        252       7204          0          0 LINE AAA
194   0        252        252       7204          0          0 LOCAL AAA
  67   0        252        252       7204          0          0 Bryce I2C CMD Qu
196   0        252        252       7204          0          0 VSP_MGR
  66   0          0          0       7204          0          0 HDV background
198   0        252        252       7204          0          0 Crypto Support
199   0          0          0       7204          0          0 IPSECv6 PS Proc
115   0          0          0       7204          0          0 X.25 Encaps Mana
  65   0        252        252       7204          0          0 FLEX DNLD MAIN
202   0        252        252       7204          0          0 VPM_MWI_BACKGROU
  81   0          0          0       7204          0          0 EAP Framework
165   0          0          0       7204          0          0 MQC Flow Event B
205   0          0          0       7204          0          0 FB/KS Log HouseK
206   0        252        252       7204          0          0 EPHONE MWI BG Pr
  64   0          0          0       7204          0          0 DSPFARM DSP READ
208   0        252        252       7204          0          0 VOICE REG BG Pro
209   0          0          0       7204          0          0 Presence Process
117   0          0          0       7204          0          0 AC Switch
  62   0        252        252       7204          0          0 SM Monitor
  61   0        252        252       7204          0          0 Netclock Backgro
  80   0          0          0       7204          0          0 MAB Framework
168   0        252        252       7204          0          0 Inspect process
  59   0        252        252       7204          0          0 ESWILPPM
170   0          0          0       7204          0          0 Authentication P
  57   0        252        252       7204          0          0 ESWPPM
  56   0          0          0       7204          0          0 ARL Table Manage
200   0          0          0       7204          0          0 EPM MAIN PROCESS
249   0          0          0       7204          0          0 Crypto cTCP proc
  51   0          0          0       7204          0          0 Token Daemon
222   0          0          0       7204          0          0 Crypto INT
  50   0          0          0       7204          0          0 AggMgr Process
  49   0          0        600       7204          0          0 Per-minute Jobs
  48   0        252        252       7204          0          0 Compute load avg
226   0          0          0       7204          0          0 IPSEC manual key
  47   0          0          0       7204          0          0 Net Input
228   0          0          0       7204          0          0 CRYPTO QoS proce
  45   0          0          0       7204          0          0 IPSEC HA Mgr
230   0          0          0       7204          0          0 Crypto PAS Proc
  44   0          0          0       7204          0          0 IKE HA Mgr
232   0          0          0       7204          0          0 GDOI GM Process
233   0          0          0       7204          0          0 UNICAST REKEY
234   0          0          0       7204          0          0 UNICAST REKEY AC
  42   0        252       1312       7204          0          0 TTY Background
236   0          0          0       7204          0          0 Multi-ISA Event
237   0          0          0       7204          0          0 Multi-ISA Cleanu
238   0        252        252       7204          0          0 Control-plane ho
239   0          0          0       7204          0          0 PM Callback
240   0          0          0       7204          0          0 Atheros LED Ctro
   6   0      52076     262844       7204      10660      98404 Pool Manager
   7   0        252        252       7204          0          0 Timers
243   0      51656     283184       7204          0          0 AAA SEND STOP EV
  38   0          0          0       7204          0          0 Critical Bkgnd
  37   0          0          0       7204          0          0 Inode Table Dest
246   0        252        252       7204          0          0 RMON Recycle Pro
247   0        252        252       7204          0          0 RMON Deferred Se
  10   0        252        252       7204          0          0 Environmental mo
  12   0          0          0       7204          0          0 IPC Dynamic Cach
250   0          0          0       7204          0          0 trunk conditioni
  34   0          0          0       7204          0          0 SERIAL A'detect
  32   0        252        252       7204          0          0 GraphIt
  31   0        252        252       7204          0          0 SMART
  13   0          0          0       7204          0          0 IPC Zone Manager
  29   0          0          0       7204          0          0 RO Notify Timers
  28   0        252        252       7204          0          0 Serial Backgroun
  27   0          0          0       7204          0          0 HC Counter Timer
  24   0        252        252       7204          0          0 DDR Timers
  22   0          0          0       7204          0          0 AAA_SERVER_DEADT
  21   0        252        252       7204          0          0 AAA high-capacit
  20   0        252        252       7204          0          0 ATM Idle Timer
  19   0       6348       2476       7204        780          0 ARP Background
  17   0          0          0       7204          0          0 IPC BackPressure
265   0          0          0       7204          0          0 IP SLA MPLSLM Pr
266   0          0          0       7204          0          0 VPDN Test
  15   0          0          0       7204          0          0 IPC Deferred Por
269   0          0       2500       7204          0          0 crypto sw pk pro
  14   0          0          0       7204          0          0 IPC Periodic Tim
188   0          0          0       7068          0          0 cpf_process_msg_
109   0      32016          0       7068          0          0 TACACS+
  11   0          0          0       7068          0          0 chkpt message ha
169   0          0          0       7068          0          0 DHCPD Timer
  30   0          0          0       4204          0          0 RMI RM Notify Wa
  60   0        252        252       4204          0          0 Eswilp Storm Con
  58   0        252        252       4204          0          0 Eswilp Storm Con
   2   0        252        252       4204          0          0 Load Meter
  53   0          0          0       4204          0          0 dev_device_remov
  52   0          0          0       4204          0          0 dev_device_inser
                                 37611736 Total
766
