Community Member
Recall
Hi everybody.
I have a question.
In Analog Telephony systems, if i call to any ext. and this is busy, i can press "flash" + "*" + "5" and when the ext. is free, then both extensions ringing (recall if bussy feature)
Anybody know if i can do the some in Cisco Call Managers?
Regards.
Bronze
Re: Recall
CCM 3.3(3) (not sure about v2 I have not used it) has a CallBack feature that works as you described. There is a callback button that you can push to get the service.
Geoff
Community Member
Re: Recall
Yes, i create a Softkey Template with callback feature.
Thank you!
Rodrigo
88
