11-22-2002 10:07 AM - edited 03-12-2019 09:41 PM
We are trying to get a switch with Q.931 output to send traffic to us. The switch is an ECT switch that uses NMS voice cards. The switch is sending traffic to PSTN termination and it is working well. However, when it sends traffic to As5300 or AS5400, the called digits seem to be truncated. We have debugged the call using debug isdn q931 and debug voice ccapi inout. It appears that the call cycle is being completed, but the calls are not going through because called digits are not being fully received by the CISCO GW. Eg the number being called is 00442075709976, but the numbers being received at the CISCO GW are 004420757. We are seeking urgent solutions. Can any one help?
Solved! Go to Solution.
11-25-2002 10:35 AM
the problem you are having is that the switch doesnt send you the full number en-block but in overlap mode. This means as soon as the switch knows the call is for you without knowing all the following digits, the call is switched to your AS5400. This is a big difference between europe (where number length is usually more or less variable) and USA (where its fixed).
you can fix this problem by doing the following:
isdn overlap-receiving
(without the other parameters)
and make your dial peers not match any destination until you got the full length number. Your dial peers have direct-inward-dial and dial-pattern 00T. This means as soon as the prefix 00 is matched, the call is established further.
As you can see in your debug, you get '004420740', and the information messages with the additional digits. As '004420740', already matches 00T, the call is already progressed to the VoIP cloud. The destination network will then be feeded with the following digits to come which is fine as long as it understands them. Now some older VoIP H323 equipment cant handle overlap digits following so you should not proceed into the VoIP cloud unless you have received all digits. In this case you do:
destination-pattern 004420740.....
(add as many dots as there are digits)
or you add the full number instead to be matched.
if your problem is that the additional digits are simply not forwarded to the remote VoIP peer even it would understand overlap sending, then you can try:
voice service voip
signaling forward unconditional
A few info's from your trace:
a) your sending switch doesnt know how long the number should be. there's no indication about the end of the number. If he would know you would get "SENDING COMPLETE" information with the last digit.
b) your device doesnt know it either as otherwhise it would signal sending complete back on the last digit received to indicate that it wont accept any furtther digits.
there's nothing wrong with that though. Maybe only your remote device how long the number will be. Really depends on the application and networks used.
11-24-2002 04:17 PM
router configs? debug ISDN q931 logs ?
Can't help without more information.
11-25-2002 08:37 AM
The config is as follows... The ISDN Q931 log is given below.
Building configuration...
Current configuration : 93751 bytes
version 12.1
no service single-slot-reload-enable
hostname imass-GW02
no boot startup-test
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default local
aaa authentication ppp default if-needed local
resource-pool disable
voice-fastpath enable
ip subnet-zero
no ip finger
isdn switch-type primary-net5
call rsvp-sync
voice service pots
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0
h323 call start fast
fax interface-type modem
mta receive maximum-recipients 0
controller E1 6/0
pri-group timeslots 1-31
controller E1 6/1
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
controller E1 6/2
controller E1 6/3
controller E1 6/4
controller E1 6/5
controller E1 6/6
controller E1 6/7
controller E1 7/0
controller E1 7/1
controller E1 7/2
controller E1 7/3
controller E1 7/4
controller E1 7/5
controller E1 7/6
controller E1 7/7
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 213.232.102.44 255.255.255.0
duplex auto
speed 100
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/0
no ip address
shutdown
clockrate 2000000
interface Serial0/1
no ip address
shutdown
clockrate 2000000
no cdp enable
interface Serial6/0:15
no ip address
encapsulation ppp
dialer map ip 195.54.247.126 imbttest
dialer-group 1
autodetect encapsulation ppp
isdn overlap-receiving T302 3000
isdn incoming-voice modem
isdn send-alerting
peer default ip address pool setup_pool
no cdp enable
ppp authentication chap pap
ppp multilink
interface Async1/00
ip unnumbered FastEthernet0/0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
interface Async1/01
encapsulation ppp
interface Async1/02
encapsulation ppp
interface Async1/03
encapsulation ppp
interface Async1/04
encapsulation ppp
interface Async1/05
encapsulation ppp
interface Async1/06
encapsulation ppp
interface Async1/07
encapsulation ppp
interface Async1/08
interface Async5/59
encapsulation ppp
interface Group-Async0
no ip address
no group-range
interface Group-Async1
encapsulation ppp
group-range 5/60 5/107
ip local pool setup_pool 195.54.247.97 195.54.247.127
ip classless
ip route 0.0.0.0 0.0.0.0 213.232.102.1
no ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
voice-port 6/0:D
translate calling 1
cptone GB
timeouts interdigit 2
bearer-cap Speech
voice-port 6/1:0
voice-port 6/2:0
voice-port 6/3:0
voice-port 6/4:0
voice-port 6/5:0
voice-port 6/6:0
voice-port 6/7:0
voice-port 7/0:0
voice-port 7/1:0
voice-port 7/2:0
voice-port 7/3:0
voice-port 7/4:0
voice-port 7/5:0
dial-peer voice 1 voip
incoming called-number .
destination-pattern 00T
progress_ind setup enable 0
session target ipv4:195.54.247.126
dtmf-relay h245-alphanumeric
codec g711alaw
dial-peer voice 2 pots
direct-inward-dial
port 6/0:D
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line aux 0
line 1/00 1/59
no flush-at-activation
autoselect during-login
autoselect ppp
modem Dialin
line 2/00 5/107
autoselect ppp
modem Dialin
scheduler allocate 10000 400
end
imass-GW02#
debug ISDN q931 Log
Looking at the following log, It is evident that the Telco switch is sending all the digits. But the Setup_ack is sent by as5400 even before all the digits are completely received. Please help me out.
imass-GW02#
*Jan 6 17:47:34.061: %SYS-5-CONFIG_I: Configured from console by kiran on conso
le
imass-GW02#
*Jan 6 17:48:03.481: ISDN Se6/0:15: RX <- SETUP pd = 8 callref = 0x0C01
*Jan 6 17:48:03.481: Bearer Capability i = 0x8090A3
*Jan 6 17:48:03.481: Channel ID i = 0xA18381
*Jan 6 17:48:03.481: Calling Party Number i = 0x21A3, '2074014200', Pla
n:ISDN, Type:National
*Jan 6 17:48:03.485: Called Party Number i = 0x81, '004420740', Plan:IS
DN, Type:Unknown
*Jan 6 17:48:03.485: High Layer Compat i = 0x9181
*Jan 6 17:48:03.485: ISDN Se6/0:15: TX -> SETUP_ACK pd = 8 callref = 0x8C01
*Jan 6 17:48:03.485: Channel ID i = 0xA98381
*Jan 6 17:48:03.861: ISDN Se6/0:15: RX <- INFORMATION pd = 8 callref = 0x0C01
*Jan 6 17:48:03.861: Called Party Number i = 0x80, '1', Plan:Unknown, T
ype:Unknown
imass-GW02#
*Jan 6 17:48:05.433: ISDN Se6/0:15: RX <- INFORMATION pd = 8 callref = 0x0C01
*Jan 6 17:48:05.433: Called Party Number i = 0x80, '4', Plan:Unknown, T
ype:Unknown
*Jan 6 17:48:05.893: ISDN Se6/0:15: RX <- INFORMATION pd = 8 callref = 0x0C01
*Jan 6 17:48:05.893: Called Party Number i = 0x80, '2', Plan:Unknown, T
ype:Unknown
*Jan 6 17:48:06.073: ISDN Se6/0:15: RX <- INFORMATION pd = 8 callref = 0x0C01
*Jan 6 17:48:06.073: Called Party Number i = 0x80, '2', Plan:Unknown, T
ype:Unknown
*Jan 6 17:48:06.261: ISDN Se6/0:15: RX <- INFORMATION pd = 8 callref = 0x0C01
*Jan 6 17:48:06.261: Called Party Number i = 0x80, '2', Plan:Unknown, T
ype:Unknown
imass-GW02#
*Jan 6 17:48:09.265: ISDN Se6/0:15: TX -> CALL_PROC pd = 8 callref = 0x8C01
*Jan 6 17:48:09.265: ISDN Se6/0:15: TX -> DISCONNECT pd = 8 callref = 0x8C01
*Jan 6 17:48:09.265: Cause i = 0x8081 - Unallocated/unassigned number
*Jan 6 17:48:09.289: ISDN Se6/0:15: RX <- RELEASE pd = 8 callref = 0x0C01
*Jan 6 17:48:09.289: ISDN Se6/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x8C0
11-25-2002 10:35 AM
voice service voip
