Recording step doesn't record without terminating key
The subject pretty much says it all. I have a script that records a caller message and stores it in a SQL server, please no comments about the evils of blobs, it's low volume. The problem is if they don't press # after the message it doesn't actually save the message. Am I doing something wrong or is that how it's supposed to work?
Anonymous
N/A
Re: Recording step doesn't record without terminating key
Try this out:
Run the script.
(1) Recording your message, press any dtmf key to terminate your recording.
(2) The script will then play "the message is [your messasge], to keep it press 1, to discard it press 2."
(3)Press 1 twice(this is because bug CSCdt93003, the first dtmf key is lost after recording), you should hear "message saved."
Silver
If you don't want to wait for a positive confirmation (eg. #) or for the timeout, then it implies that the caller is hanging up.
You can use the On Exception Goto step to catch the ContactInactiveException when a caller hangs up.
When the contact terminates, if a media step is executed that relies on a contact, it will trigger this exception handler. This step will catch the exception and go to the label you have specified. Here you can email out the recorded wav file .
I would strongly recommend that you immediately use the On Exception Clear step to "cancel" the On Exception Goto inside the destination label. This will avoid potentially looping.
This sounds like what I need. I'll try this right away. Thanks!
Do you know where I should add the On Exception Goto to? Should it be in the Unsuccesful branch of the recording step?
Bronze
You need to use the OnException Goto before the Recording step. It is alway's very important to
clear the On Exception Goto's to avoid looping.
Example:
OnException(ContactInactiveException) Goto Label
Recording step
Label
Clear Exception (ContactInactiveException)
Hope this helps
It did help! Thanks to both of you! My script now functions properly without a terminating key.
Cliff
124
