Register phones
When using SRST with max ephones = 24 is it just first come first serve and after 24 no more will register?
How do you select which phones you want to register?
1 REPLY
Re: Register phones
Yes, if more than 24 phones are using a devicepool with the SRST option configured, the first 24 phones are being served.
Suggestion: If you want to control specific phones, create/copy a seperate devicepool with the SRST option and configure the phones which should be served with this devicepool. For the others, change the existing devicepool and "disable" the SRST option.
94
