Registry Setting for IPCC servers
I’m familiar with at least one registry setting that need to be changed manually from the default parameter, this happens when the customer is hitting max node execution within one IP-IVR script, the default value 200 nodes but you can increase it by changing this value using regedit and the following path:
HKEY_LOCAL_MACHINE\SOFTWARE\GEOTEL\ICR\CUSTOMER\ROUTERA\ROUTER\CURRENTVERSION\CONFIGURATION\SCRIPT
I’m looking for other manual registry settings that may need to be done on other scenarios, Is there any document on this issue?
Ronen
1 REPLY
Silver
Re: Registry Setting for IPCC servers
This document talks about some registry changes required for certain cases. Please take a look.
http://www.cisco.com/en/US/products/sw/custcosw/ps1844/products_tech_note09186a00800b6a82.shtml#reg_set_incorrect
90
