remote config using H323 and SRST
I am going to deploy this config to our remote site and i want to know if you guys think its correctly written. I haven't deployed this in a lab because we dont have extra gateways laying around. Is there a better way of writing this config?
Thanks in advance.
isdn switch-type primary-ni
voice class codec 1
codec preference 1 g711ulaw
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-15
controller T1 3/0
framing sf
linecode ami
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-5ess
isdn incoming-voice voice
no cdp enable
voice-port 1/0:23
echo-cancel coverage 32
mgcp profile default
dial-peer cor custom
dial-peer voice 100 voip
preference 1
destination-pattern 1...
progress_ind setup enable 3
voice-class codec 1
session target ipv4:10.128.1.4
dtmf-relay h245-signal h245-alphanumeric
dial-peer voice 101 voip
preference 1
destination-pattern 2...
voice-class codec 1
session target ipv:10.128.1.4
dial-peer voice 102 voip
preference 1
voice-class codec 1
dial-peer voice 103 voip
preference 1
destination-pattern 3...
voice-class codec 1
dial-peer voice 104 voip
preference 1
destination-pattern 4...
voice-class codec 1
preference 2
voice-class codec 1
session target ipv4:10.128.1.5
dial-peer voice 105 voip
preference 2
voice-class codec 1
dial-peer voice 106 voip
preference 2
voice-class codec 1
dial-peer voice 107 voip
preference 2
voice-class codec 1
dial-peer voice 10 pots
preference 1
destination-pattern 9.......
progress_ind alert enable 8
direct-inward-dial
port 1/0:23
dial-peer voice 11 pots
destination-pattern 9411
progress_ind connect enable 8
port 1/0:23
prefix 411
dial-peer voice 12 pots
destination-pattern 9911
direct-inward-dial
port 1/0:23
prefix 911
dial-peer voice 20 pots
destination-pattern 91..........
direct-inward-dial
port 1/0:23
prefix 1
dial-peer voice 21 pots
destination-pattern 9011T
direct-inward-dial
port 1/0:23
prefix 011
gateway
call-manager-fallback
ip source-address port 2000
max-ephones 20
max-dn 100
access-code pri 9........... direct-inward-dial
line con 0
line aux 0
line vty 0 4
password 7 104B19101618160E5D
login
end
Silver
Re: remote config using H323 and SRST
It would be really difficult to validate your configuration with out the knowledge of your network topo and dial plans. If you cant try it out in lab, it will always be wise to declare sufficient downtime and have proper rollback plans.
Dial-peers 101 and 102 appear to be the same apart from you've a mistake in 101 ----- session target ipv: should be ipv4: ----- but you only need 1 of them.
you have 2 dial peer 104 going to different destinations.
Other than that it look spretty good, but there's no substitute for having the router point out your mistakes.
Paul
204
