Repeat Call Handlers
Is there a way to specify that a Call Handler should repeat X number of times before I have it either disconnect, transfer, or take a message? Right now I have them transfering back to themselves after they play which is creating possible infinate loop errors. I would like to be able to have a call handler repeat tow or three times before I have it disconnect? Any ideas?<br><br>Thanks<br><br>
1 REPLY
Anonymous
N/A
Re: Repeat Call Handlers
If the CH is looped back to itself, it should only go 10 times. After that, it should recognize that it's looped, post a warning (probably what you are seeing) and then ditch the call.
I can't think of anyway to make one CH loop X amount of times, but you could work around it by building 3 exactly the same CHs (when you create CHs 2 and 3, you can base them off of CH 1). Just chain these CHs together and change the last one to hang up if the caller doesn't do anything.
Steve Olivier
Software Engineer
Cisco Systems
100
