Replacement License
If the existing unity server (ver 4.01) crash, and need to be replaced by a new unity server. (the same model)
Is that just simply move the hard disks from the faulty server to new server and then install the replacement license or need to perform additional steps to recover the unity?
Thx a lot
1 REPLY
Gold
Re: Replacement License
You could do that assuming that the hard drive wasn't the component that crashed. We don't test swapping drives from one server to another so Cisco isn't going to guarantee that it will work.
The recommended (and supported) method of backup would be to use software backup agents such as Backup Exec or the Cisco Unity Disaster Recovery Tool.
Hope this helps...
Keith
144
