request circuit/channel not avaiable ISDN
Someone Know how to fix this!!!
I have a AS5300 working with ISDN link and when I try to send a call (originate) I had request circuit/channel not avaiable:
__________________________________________
00:40:04: ISDN Se0:15: RX <- SETUP pd = 8 callref = 0x0012
00:40:04: Sending Complete
00:40:04: Bearer Capability i = 0x9090A3
00:40:04: Channel ID i = 0xA9839F
00:40:04: Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have i
n-band info
00:40:04: Called Party Number i = 0x91, '1136734130', Plan:ISDN, Type:In
ternational
00:40:04: ISDN Se0:15: Incoming call id = 0x0007, dsl 0
00:40:04: ISDN Se0:15: L3-EVT: callref = 0x8012 SETUP:U0_Setup()
00:40:04: ISDN Se0:15: L3-SDL: callref = 0x8012 NULL_STATE->CALL_PRESENT
00:40:04: ISDN Se0:15: NegotiateBchan: bchan 31 intid 0 serv_st 0 chan_st 0 call
id 0x0000 ev 0x90 n/w? 1
00:40:04: Negotiated int_id 0 bchan 0 cr=0x8012 callid=0x0007 lo_chan 31 final i
nt_id/bchan 0/31 cause 0x0
00:40:04: ISDN Se0:15: LIF_EVENT: ces/callid 1/0x7 CALL_INCOMING
00:40:04: ISDN Se0:15: CALL_INCOMING dsl 0 bchan 30
00:40:04: ISDN Se0:15: CALL_INCOMING: call type is VOICE ALAW, bchan = 30
00:40:04: ISDN Se0:15: Event: Checking if call is not ISDN end to end
00:40:04: ISDN Se0:15: Event: Adjusting speed to user selection 64K
00:40:04: ISDN Se0:15: Event: Received a VOICE call from <unknown> on B30 at 64
Kb/s
00:40:04: ISDN Se0:15: RM returned call_type 1 resource type 0 response 2
00:40:04: ISDN Se0:15: L3-EVT: callref = 0x8012 CC_CALL_PROC_REQ:U6_CallProcReq(
00:40:04: ISDN Se0:15: L3-SDL: callref = 0x8012 CALL_PRESENT->IN_CALL_PROC
00:40:04: ISDN Se0:15: INCOMING CALL: VOICE ERROR: Requested circuit/channel not
available(0x2C): bchan 30, call id 7
00:40:04: ISDN Se0:15: process_disconnect(): call id 0x7, call type is VOICE, b_
idb 0x6216D720, ces 1, cause Requested circuit/channel not available(0x2C)
00:40:04: ISDN Se0:15: L3-EVT: callref = 0x8012 CC_DISCONNECT_REQ:Ux_DiscReq()
00:40:04: ISDN Se0:15: L3-SDL: callref = 0x8012 IN_CALL_PROC->DISCONNECT_REQUEST
00:40:04: ISDN Se0:15: TX -> CALL_PROC pd = 8 callref = 0x8012
00:40:04: ISDN Se0:15: TX -> DISCONNECT pd = 8 callref = 0x8012
00:40:04: Cause i = 0x82AC - Requested circuit/channel not available
00:40:04: ISDN Se0:15: RX <- RELEASE pd = 8 callref = 0x0012
00:40:04: ISDN Se0:15: L3-EVT: callref = 0x8012 RELEASE:U11_Release()
00:40:04: ISDN Se0:15: L3-SDL: callref = 0x8012 DISCONNECT_REQUEST->NULL_STATE
00:40:04: ISDN Se0:15: CCPRI_ReleaseCall(): bchan 31, call id 0x7, call type VOI
CE
00:40:04: CCPRI_ReleaseChan released b_dsl 0 B_Chan 31
00:40:04: ISDN Se0:15: LIF_EVENT: ces/callid 1/0x7 CALL_CLEARED
00:40:04: ISDN Se0:15: received CALL_CLEARED call_id 0x7
00:40:04: no resend setup, no redial
00:40:04: ISDN Se0:15: TX -> RELEASE_COMP pd = 8 callref = 0x8012
The setup is:
isdn switch-type primary-net5
voice call send-alert
controller E1 0
framing NO-CRC4
clock source line primary
pri-group timeslots 1-31
interface Serial0:15
no ip address
autodetect encapsulation ppp v120 lapb-ta
isdn not-end-to-end 64
isdn protocol-emulate network
isdn incoming-voice modem
isdn T310 4000
isdn send-alerting
isdn sending-complete
no cdp enable
voice-port 0:D
compand-type a-law
no comfort-noise
dial-peer voice 36 voip
destination-pattern 113673T
session target ipv4:200.186.217.54
tech-prefix 01155
  • Other Collaboration Voice and Video Subjects
Re: request circuit/channel not avaiable ISDN
S,
You need to build up a voice class with specific codecs in it and assign it to the incoming dial-peer. AS-5300s are a bit funny like that.
I would also look to set the incoming number type to unknown as I've had problems with this in the past.
voice class codec 1
codec preference 2 g711ulaw
codec preference 3 g729r8
destination-pattern 113673.
progress_ind setup enable 3
voice-class codec 1
Paul
Paul,
First of all Thank you for your prompt answer.
I made the changes and did not work. However I could check that when, in the s0:15 interface I do not add the command
isdn incoming voice modem
I get other error:
01:23:41: ISDN Se0:15: TX -> RELEASE_COMP pd = 8 callref = 0x801F
01:23:41: Cause i = 0x82D8 - Incompatible destination
and when I use
isdn incoming-voice data
I got :
01:20:19: ISDN Se0:15: RX <- DISCONNECT pd = 8 callref = 0x001E
01:20:19: Cause i = 0x849F - Normal, unspecified
but no voice could pass through.
Any ideas, folks ?
Try setting the
isdn incoming-voice voice
are you sure you have a voip platform, the dial access AS-5300 bundle does not support voice.
Paul
There is no voice option on this command isdn incoming voice.
I use the IOS version:
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(xa3plus.0.10.0), CISCO DEVELOP
MENT TEST VERSION
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 19-Mar-02 13:10 by hwcheng
Image text-base: 0x60008950, data-base: 0x60FF8000
I 've already run this box as R2 instead of ISDN, And runs ok!! But in R2 I do not have the disconnect reason codes (carrier required) as I can get in ISDN, that's why I am trying ISDN.
Samy
Do you get secondary dial tone when "incoming-voice modem"
is set? If so, you might try adding a pots dial-peer like this:
dial-peer voice 99 pots
port 0:D
direct-inward-dial
Shelly
Thank you, Shelly It work edfine. I forgot to add Pots dial-peer at the ports.
416
