required privilege
I am getting this "wrong password" error while installing unity 2.4.6 on win2k joined to an NT domain.<br>the tempu file shows:<br>Password validation failed [1314]: A required privilege is not held by the client<br>I checked and verified that my accound has those rights:<br><br>Logon as a service<br>Restore files and directories<br>Act as a part of operating system<br><br>Syscheck Pre-install just went ok without any problems.<br>What could be the next thing to check?<br>thanks<br>Murat<br><br><br><br><br>Murat Tiryakioglu<br>Cisco, Customer Support Engineer, AVVID Team
Anonymous
N/A
Re: required privilege
A logoff and a logon mysteriously solved the issue :)
but now my Service Provider 1 insists on pointing out to SelsiusTSP.TSP instead of AVskinny.tsp :(
murat
Murat Tiryakioglu
Anonymous
N/A
You might want to create a separate post for the second under IP integration. Are you W2K or NT4? The telephony stuff between the two are a bit different.
120
