Resource unavailable, call rejected
Problem : as soon as I dial a number,number just vanishes from the phone.
I looked at cisco CDR messages::: DisconnectCause 15 , DisconnectText call rejected (21)
Debug isdn gives::: Resource unavailable..Why?
*Mar 2 12:30:35.838: ISDN Se0/2/1:15 **ERROR**: cdapi_process_connect_resp: cdapi sez to reject the call (appl rejected?)
*Mar 2 12:30:35.838: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9100
Cause i = 0x82AF - Resource unavailable, unspecified
Numbers I was dialing was '8700276161
Note, this happens when call volume is high.the cpu processor util was normal.
Set up is like this
Nortel pbx-->Cisco3845voiceh323gateway-->voip
Thanks in advance
Re: Resource unavailable, call rejected
You might be running out of DSP's. Check the number of PVDM's in the Gateway.
PVDMs we have 256onboard and 60 in Network module. process codec used wazs g729r8.
Cause i = 0x82AF
82 - From the public network near the local user (local telco switch).
AF - Resources unavailable, unspecified. The requested channel or service is unavailable
for an unknown reason. This can be a temporary problem.
http://www.cisco.com/warp/public/129/isdn_disc_code.html
What is your IOS version? Is the circuit running clean, any errors on the interface?
IOS version is 12.4 2
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(2)T3,
RELEASE SOFTWARE (fc4)
pri interface looksokay,with small error, 2 interfaces shows 6 error, and 3 crc error, but nothing major.
Voip side circuit was clean throughout the day.
- i feel some kind of performance degradation? only thing i could imagine was dsp farm is not configured.. will it help..?
or any suggestions pls
CSCsx67255
Leonardo Oliveira www.avvid.net "Scientia potentia est"
4717
