Restrict inbound pots calls based on ANI?
Is it possible to allow/disallow inbound pots calls based on the ANI on a AS5300 within the dial peer configuration? If so how?
So I can only allow calls from a certain ANI access through to match an outbound dial peer?
1 REPLY
Silver
Re: Restrict inbound pots calls based on ANI?
What you can do is use cor-lists. The way cor lists work is that, you can define which inbound dial peers are allowed to use which outbound dial peers. Each list has a subset of groups and based on those groups you can give certain lists permissions etc. It is kind of complicated but thats the only way I can think of to do it. The way you would match an inbound dial peer, would be to use the answer address under the dial peer to match the ani and apply the restrictive cor list under there.
Look for configuring cor lists in the CCO.
112
