Restricting Codecs using MGCP
Is there a way to restrict the type of codecs that a 2524 will send in a call setup message to a media gateway controller using MGCP.
Currently it is sending 7 options. All that I want it to send back is just G711 and G729r8.
I looked at the mgcp codec command but that is setting the default codec and not setting the available codecs.
Anonymous
N/A
Re: Restricting Codecs using MGCP
Ment to say 2421 router and not a 2524
Anonymous
N/A
all IOS gateways (incl 2421) send entire list of codec to the CA if the local conn options does not specify a codec. You cannot restrict this via command line
139
