Ring Down Circuit
cairns-a
I have CallMgr. 4.1(3) and want to know if you can do a ring down circuit?
What I want, is that when an IP phone is picked up it automatically rings an ext.
Trae
Aaron Harrison
You can do this by adding a Partition that just contains a translation pattern and nothing else. The trans pattern should translate nothing (a blank string) to the number you want the phone to dial.
Add this partition to a new CSS, and assign the CSS to the phone.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yep - that's a much nicer explanation :-)
